Alrighty then,
I did 22,000 miles on a 790 with D&D pipes, a K&N air filter, expensive NH bellmouth, and some Thruxton needles,
BUT the ristrictor plate was removed.
I've since done 600 miles on my current 790 with the same D&D pipes, same K&N air filter, same NH bellmouth, and the same Thruxton needles..........
but with the restrictor plate still in place.
The following is my conclusion, make of it what you will:
With the restrictor plate removed, throttle response is improved. But she needs to be spun up with enough air moving into the air box for everything to be married and work in concert. The engine feels like it has more *punch* when the conditions are right, but THAT'S what makes this combination left for lacking..... conditions gotta be 'right'.
If you're tooling along in a high gear at cruising speed, but not fast enough to be forcing air up the throats of the carb's..... and you grab a hand full of throttle, the engine reacts in a fashion similar to "turbo lag"..... a slight delay before the party. I would not have been able to identify this "lag" had I not ridden my current bike with it's restrictor/divider plate in place.
With the plate in place, the engine is more user friendly, the power more docile and linear, and more responsive to throttle input when you're just tooling along at legal speeds in a higher gear. I don't feel any loss of power in the broad scheme of things, and when I researched the various recommendations for jet size with the plate removed, they didn't call for larger main jets unless there were additional factors in the changes being made.
Bottom line, if you live in the 'party zone' of your tach while chasing little Honda 600's through the canyons, and you don't want to go to the expense of an air box elimination, a restrictor plate removal will give you more (felt) throttle response, but it won't give you significantly more power.
At least, that's what I've concluded.......
and I'm leaving mine in. If you wanna tear your air box apart to get at the plate, you may as well remove it and install pods.
[ This message was edited by: FattRat on 2006-11-26 11:58 ]
