AdvanstarMotorcycleShowsBikeBanditMotorcycle.comTrident-Exhausts.com
BikeBandit
Old 11-21-2006   #1 (permalink)
bbx45lc
What is the easiest way to fix a broken kick pawl?
[ This message was edited by: bbx45lc on 2006-11-21 18:52 ]
Old 11-21-2006   #2 (permalink)
Favorite Bike: '06 T100
road_dog's Avatar
Easiest??? Pay somebody else. :hihi:
Phil (road dog)
Click on the Image
for Larger Picture
road_dog is offline   Reply With Quote
Old 11-21-2006   #3 (permalink)
Favorite Bike: 05 Black Speedmaster
Build it up with weld and grind it to shape.
Old 11-22-2006   #4 (permalink)
Favorite Bike: The one I'm on!
Other Motorcycle: Red 2006 Sprint
Extra Motorcycle: Red/Black 2006 Bonnie
Nope. Yours is the fastest way, Normandy. Road_dog has the easiest way.
So how's your ankle, bbx45lc?
[ This message was edited by: walt on 2006-11-22 00:28 ]
I'm just browsing, thank you.
walt is offline   Reply With Quote
Old 11-27-2006   #5 (permalink)
bbx45lc
thanks guys,
the reason I was asking was because when I was trying to tune the carbs as well as set the hunt mag timing (requiring a lot of kicking) the pedal just fell and did not come back up. I took the outer cover off and everything there seemed to be in place, the spring looked good, so I put it back together. But deeper inside I could feel the pawl trying to catch in something but not succeeding.
beau
Old 11-28-2006   #6 (permalink)
Favorite Bike: 98 Thunderbird
Beau, you should ask in the Classic vintage & veteran forum, there are lots of experts on the older bikes contributing there.
[ This message was edited by: Slinky on 2006-11-28 02:20 ]
Old 11-28-2006   #7 (permalink)
bbx45lc
Thanks Slinky
beau
Old 11-29-2006   #8 (permalink)
Favorite Bike: 1967 triumph T120R old sc
el_nino3's Avatar
i don't know what is the problem with yours but when i got kick prolbs. it was due to the ratchet and pinion gears , worn teeth , also ratchet. pin. bearing was shot. be careful if u try to replace it , mine was a real bear to get out even after heating up casing around bearing but i overheated mine by running a dry trans. and now still working on it kicker works fine but not getting to shift into all gears the old ones can be a pain but sooner or later i should run out of things to fix on my build 67 T120R ................ then again? .............good luck
golf is the only thing in this world that can ruin a nice walk in the country......
el_nino3 is offline   Reply With Quote
kick start problem on 73 Bonneville wolfwrangler Classic, Vintage & Veteran 4 12-03-2007 10:43 PM
Love my T100...wish it had a kick start kenhadie Twins Technical Talk 22 09-30-2007 10:59 PM
kick start question glw Classic, Vintage & Veteran 14 05-04-2007 08:23 AM
Kick-start on Rebel??? SBBonnie Biker Hang-Out 7 03-29-2007 09:41 PM
