I'm a bit undecided on this. I was out last night with MY sealed beam, but it's not aligned correctly so I can't say with any certainty that the following is true:
Sure, it's brighter..... BUT I find that it doesn't paint the road in front of you with ample light. I think it needs to be married to another bulb like it for it to work right. By itself, it's a pin-point beam of light. As I suggest above, my beam is not adjusted correctly yet..... so I may change my mind on this, but I doubt it.
I would suggest spending instead the big bucks for an upgraded PIAA bulb with a rating higher than our factory bulb. They run cooler than the cheap SilverStars, put out better light, and last MUCH longer.
That lens on our motorcycles is DESIGNED to spread the light out in front of our bikes, I don't think the answer is to replace it with a headlamp designed for a car.....
[ This message was edited by: FattRat on 2006-11-20 09:46 ]
