My headlight beam seemed high too, when I bought the bike. It didn't really want to stay lower, either, when I adjusted.
I had to open the headlight shell to plug in the tachometer wire, and I had to undo the two bolts to install the flyscreen, which I did at the same time. When I reassembled, I lowered the beam.
If you open the headlight shell and fiddle with the wires a bit, you might be able to pull out enough slack to lower it. You probably need less than a centimeter.
Since then, I've decided to raise the headlight beam a bit, put in a brighter bulb, and lube the speedo cable, so I'll be at it again on a warmish day or more likely next spring.
Marty
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
