18 Tooth Sprocket - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 11-10-2006, 11:22 PM   #1 (permalink)
I know everybody has heard this already, but I just had an 18 Tooth Sprocket put on my standard Bonneville today and then took a little ride at highway speeds and what a freakin' difference For the better of course. The engine seems to be much more relaxed (which everybody said it would). Way Cool!!!! This is by far the best modification anyone from this post has recommended. Happy Trails.
My Bonneville = My Therapy!!
Bigman is offline   Reply With Quote
Old 11-10-2006, 11:32 PM   #2 (permalink)
bonnevillebilly's Avatar
I've had the 19T in mine for about a year now, and there
is no going back for me. I love it, I also think it is one of the
cheapest and best mod I've done.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 11-11-2006, 01:16 AM   #3 (permalink)
How much does the 18 tooth affect your accelleration? I rarely drive over 85mph, but I like my turbo boost.
I was actually considering switching to a 16t.
poffypoffa is offline   Reply With Quote
Old 11-11-2006, 03:50 AM   #4 (permalink)
Favourite Bike: Bonneville
Other Motorcycle: 2011 Rocket Roadster
I have got to say I like my 2001 with a 19T. I have K&N filter, A1 removed, snorkle removed, baffels out, and just fitted Thruxton needles replacing the stock with one shim and I am very happy the bike. Nay two up it might not be so good but for one up cruisen its great.
2001 790, A1 removed, K&N Air filter, restrictor plate removed, air box intake cover enlarged, stock needles one shim, 135 mains, 40 pilots, NH Classic Toga Mufflers - no baffles, Twin Power remap stage 1, 19T, NH Western bars, Dart flyscreen.
Motolink is online now   Reply With Quote
Old 11-11-2006, 08:44 AM   #5 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
Poffy-I have a 16T sprocket and it makes for a much more aggressive "around town" riding. You shift a lot more and you will be lucky to break 100mph with it without REALLY winding the motor up. I went on an expressway ramp and nailed it, not paying attention to shift count but traffic. It got to 95 very quickly but when I pulled the shifter up, I was surprised to find I was in 5th (and final) gear and reving hard. Definately not a highway sprocket. Around town, yes, great fun. Get one of each when you want to change things up a little.
Brooksie is offline   Reply With Quote
Old 11-11-2006, 11:52 AM   #6 (permalink)
I have to admit.....some times I do miss my 17T with the
very fast take off, She would take off like a bullet.
But, I know would miss how she feels with the 19T
at cursing speed and on the highway a lot more.
I can ride her all day at 85-90 mph and she never brakes a sweat.
She can still come off the line pretty dam fast.
I know I could never go back.
Bill
2001 Bonnie
1976 Bonnie
Old 11-11-2006, 01:19 PM   #7 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
I started with the 17T, went to the 18T, then back to the 17T. I personally like the way the bike responds with the 17T. However, I'm thinking I may want to try one of the following changes to lower the rpm just a touch at high Interstate speeds, but not quite as low as the 18T makes it:
1. Install Metzeler 140/80-17 rear tire. Larger diameter than stock will essentially provide slightly higher gearing.
2. Keep running a 17T on the countershaft, but drop the rear sprocket one tooth, from a 43T to a 42T. That would result in a final drive ratio that falls somewhere between running stock gearing and an 18T:
Stock
43/17 = 2.53:1
Drop one tooth on rear sprocket
42/17 = 2.47:1
Add one tooth to countershaft sprocket
43/18 = 2.388:1
Bob
[ This message was edited by: ohiorider on 2006-11-15 09:29 ]
Old 11-11-2006, 05:52 PM   #8 (permalink)
Brooksie's Avatar
From what I understand, the 18T works very well with the big bore mods because it lets you rev out the increased power longer resulting in higher speed. With the extra grunt the big bore gives you, you take off plenty quick.
Old 11-11-2006, 06:43 PM   #9 (permalink)
Favourite Bike: Velocette Thruxton
Thruxton's Avatar
Other Motorcycle: BMW R1100RS
Extra Motorcycle: 67 BMW R60, with sidecar
After purchasing my Bonnie I immediately went to an 18T front sprocket, I couldn't feel any difference.
As soon as the 19T sprocket became available I installed it, now I felt a difference.
I will NEVER go back to a 17 or 18 front sprocket, AND I'm thinking of loosing one or two teeth on the rear sprocket.
I've NEVER felt a lack of torque, and I ride two up frequently.
[ This message was edited by: Thruxton on 2006-11-11 16:46 ]
Loud pipes are rude and inconsiderate.
Thruxton is offline   Reply With Quote
45 tooth sprocket oldyeller Daytona Deliberations 11 08-16-2007 04:16 PM
18 or 19 tooth sprocket ajf Twins Talk 34 03-31-2007 08:16 PM
Tried th 19 tooth sprocket TTBONNE Twins Technical Talk 8 09-10-2006 01:45 PM
41 tooth sprocket mike_ Hinckley Classic Triples 3 04-01-2005 07:49 PM
18 tooth sprocket $ clubman Sprint Forum 13 02-20-2005 02:08 PM
