AdvanstarMotorcycleShows
Old 11-08-2006   #1 (permalink)
All I can say is WOW. He sent me 2 black brackets [one split for wiring,one solid] at no cost for the parts or the shipping. I used the split version since my wiring was already installed and it went on in minutes,nice,tight and secure. A very cool way to get rid of the bulky Triumph stuff and the perfect end to a crappy work day. :upthumb:
Old 11-09-2006   #2 (permalink)
Retired Legend
sweatmachine's Avatar
that is clean!
now how do I get one?
Actually I don't mind the stock gauges too much, I'd like to come up with a new way to mount them though...just another project on the back burner.
A new mounting plate would help the stock gauges, mounted flat and less obtrusive.
Old 11-09-2006   #3 (permalink)
D9
D9's Avatar
sweatmachine -
Appreciate the comment, thanks! - if you already have a mini gauge or a set of mini gauges - and it's the same one or ones as rodburner's, bonneville billy's or loxpumps (the cans mic out to 2.39" OD, from Mikes XS, also apparently available from a source on ebay) - I'll be happy to fix you up, send me a PM and let me know if you want a solid single gauge bracket, a slotted single gauge bracket, or a R/H - L/H set.
Prototyping the R/H - L/H set for Lox's bike right now, hopefully we'll get them fitted this weekend and post some pics. However, I haven't found a good way to slot the R/H - L/H set to slide wires through and maintain the needed super-tight fit (brackets are .125" aluminum with fitted neoprene gasket) so if the gauges are already on, they would need to have wires undone, slipped through the R/H - L/H brackets, and then reconnected.
If you're going single gauge and are already wired up, then the slotted single bracket is probably the way to go - likewise, if you're going single gauge but not yet installed, I'd recommend the solid single
bracket - keep in mind, these mini gauge brackets are still very much in prototype stage - hope to hear good road test results on the slotted single from rodburner... ;-)
Cheers,
D9
Bracketology
D9 is offline   Reply With Quote
Old 11-09-2006   #4 (permalink)
Retired Legend
do you have a set for the mini speedo and mini tach?
I may be interested in that...
Pic?
Old 11-09-2006   #5 (permalink)
D9
D9's Avatar
No pics on the L/H - R/H set just yet -
...be this weekend hopefully - keep ya posted...
Cheers,
D9
Bracketology
Old 11-09-2006   #6 (permalink)
Retired Legend
great, thanks!
I'll probably want to get one from ya!
Not cut/slotted, I'll get the new gauges and wire them through.
Old 11-13-2006   #7 (permalink)
Loxpump's Avatar
Here's my Speedometer/Tachometer set up, with two of D9's individual brackets.
Both with and without blacked out lower sections.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 11-13-2006   #8 (permalink)
Retired Legend
that is sweet, got a view from the top?
Old 11-13-2006   #9 (permalink)
Loxpump's Avatar
Rider View
Semper Fi!
Old 11-13-2006   #10 (permalink)
Retired Legend
Much cleaner than stock, D9, how do I get a pair?
Two for the road - new mini speedo ignition relo brackets D9 Twins Technical Talk 19 01-13-2008 07:10 PM
Generation II mini-gauge brackets Pics! D9 Twins Technical Talk 51 01-01-2008 12:04 AM
Custom R3 GaryParky The Rocket Science Forum 8 09-12-2007 12:16 PM
More brackets for mini speedos & tachs & relocating ignition D9 Twins Technical Talk 26 01-01-2007 10:05 PM
Custom Hitch Classic, Vintage & Veteran 23 10-12-2006 06:18 PM
