Old 10-22-2006   #1 (permalink)
Has anyone put Triumph heated grips on their BA or SM? I've seen a SM advertised as having Triumph grips but can only find ones for the Rocket or Tiger on the Triumph parts sites. I'm not really interested in the wraparound types so want to try a stock option.
Digger2 is offline   Reply With Quote
Old 11-21-2006   #2 (permalink)
Olav
Just saw your question. I put a set of heater elements, the kind that you wrap under the stock grips, on my 05 America about a year ago. They work very well...in fact, on the high setting the throttle grip gets too hot as the heater element is not directly on the metal of the handlebar but rather on the plastic of the throttle under the grip. Overall I am very pleased with it. Installation was simple - took about an hour including running wire and installing the switch - and cost was low. Could not find another solution - no ready to install heated grips anywhere.
Old 11-23-2006   #3 (permalink)
Olav, I also installed the same set up you mentioned.
On high setting it blows a fuse but on the low setting it works great and is plenty hot. I ran all the wiring through the bars, must have stripped a wire when pulling through the bars.
No biggie low setting is plenty hot. About $29.95 if I remember correctly.
Albuquerque, New Mexico eh? Does it get cold enough down your way hot heated grips?
Mike
Red Devil
mikemm03 is offline   Reply With Quote
NEED HELP WITH HEATED GRIPS thinkjerm Sprint Forum 4 06-17-2007 10:20 AM
Heated grips? Skvarki Twins Technical Talk 3 05-01-2007 01:59 PM
Heated Grips dirtyworm Club Cafe 14 01-24-2006 12:25 PM
Heated Grips? Merrimac Speed Triple Forum 6 12-31-2005 02:10 PM
Heated Grips pbbeck The Rocket Science Forum 10 12-08-2005 03:20 PM
