Old 10-08-2006   #1 (permalink)
meistro
HIi When the red light came on on my Tri Bonnie I got into a panic and put too much oil in
When I lift the bike straight up the sight glass is full
As I am a novice, and dont have manual with me, I am not sure how to drain some of the oil
The internet said, open the sump but I dont know where that is or how to do it.
Please advise. Robert
ps. Thanks Chris and Bon tons :???:
Old 10-08-2006   #2 (permalink)
That would be the drain plug on the front bottom of the engine.Drain out a goodly amount into a clean container,then pour some of it back in to the proper level. Do it with a cold engine so the oil is thick and easier to control.
Old 10-08-2006   #3 (permalink)
The best way to assure yourself of a clean container is get one of your wifes (mothers, significant others, etc) Tupper Ware large containers. She shouldn't mind. It is for your Triumph after all.
A 6 inch extension & socket (15MM I think?) & ratchet work great from the front.
357bob
Old 10-08-2006   #4 (permalink)
Maybe 13 MM? I said 15 MM.
357bob
Old 10-08-2006   #5 (permalink)
knew whatcha meant Bob....I do that occassionally myself...
kliff is offline   Reply With Quote
Old 10-08-2006   #6 (permalink)
Occasionally doesn't even enter into it. I do it ALL the time.
I always ask. "What's the difference between 15 MM & 13 MM?" 2 MM of course.
Like I said on his other thread he has started. Use Tupper Ware from kitchen for oil draining. (Is there an echo in here?)
357bob
Old 10-08-2006   #7 (permalink)
As for the oil light may have came on. If you shift slowly from 1st to 2nd you will see the neutral light flash. Especially at night. Makes you glance down to see what that was.
357bob
Old 10-08-2006   #8 (permalink)
There is a fitting near the drain plug that feeds the oil cooler. Put a pan under it and crack the fitting just enough so that at idle, it leaks a bit. Very conrtollable. If you do the drain plug thing, you run the risk of draining the whole shabingus, if you drop the plug into the oil and can't get it out of the swamp in time.
Mecchanica is offline   Reply With Quote
Old 10-09-2006   #9 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
Actually, depending on what kind of oil you put in when you thought you were low, you might want to drain all of the oil and replace it. If you dumped in regular 10W40 (or something) automotive oil, your bike now contains a mix of regular and synthetic oil. Mixing oil isn't the greatest idea, and if I were you I'd replace it. (If, on the other hand, you used Mobil 1 motorcycle oil, you should be fine.)
Take a look at some of the oil threads in these forums to learn more, but Triumph specifies synthetic or at least semi-synthetic motorcycle oil (15W50 or 20W50) for the Bonneville; a lot of people here including myself stick with Mobil 1. What you definitely don't want to do is run standard 10W40 or lighter automotive oil in your Bonneville.
--mark
[ This message was edited by: markbvt on 2006-10-09 09:30 ]
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline   Reply With Quote
Old 10-09-2006   #10 (permalink)
Yeah. What he said.
357bob
oil light after oil drain and refill 82triumph750 Classic, Vintage & Veteran 4 02-02-2008 01:47 AM
Oil Drain Plug Londonspride Twins Talk 4 09-09-2005 09:25 AM
Oil Drain Plug Londonspride Twins Talk 2 09-08-2005 11:29 PM
oil drain plug jeffro232 Speed Triple Forum 5 07-08-2005 11:05 AM
How many oil drain plugs are there ? shedds Hinckley Classic Triples 4 07-16-2004 01:58 AM
