Old 10-05-2006   #1 (permalink)
5bassman's Avatar
Can someone tell me the engine size on a 2005 model? Is it 790cc or 865cc?
2005 Triumph Bonneville Black
5bassman is online now   Reply With Quote
Old 10-05-2006   #2 (permalink)
790cc
Ride & Smile
TOR/Re-Jet -Air Elimination-Eliptical mirrors
johnsime is offline   Reply With Quote
Old 10-05-2006   #3 (permalink)
This applies to the Black and Standard, the T100 is 865cc
Engine and transmission
Displacement: 790.00 ccm (48.21 cubic inches)
Engine type: Twin
Stroke: 4
Power: 62.00 HP (45.3 kW)) @ 7400 RPM
Torque: 62.00 Nm (6.3 kgf-m or 45.7 ft.lbs) @ 3500 RPM
Compression: 9.2:1
Bore x stroke: 86.0 x 68.0 mm (3.4 x 2.7 inches)
Fuel system: Carburettor. Twin carburettors with throttle position sensor and electric carburettor heaters
Fuel control: DOHC
Ignition: Digital - inductive type
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Clutch: Wet, multi-plate
Physical measures
Dry weight: 205.0 kg (451.9 pounds)
Seat height: 775 mm (30.5 inches) If adjustable, lowest setting.
Overall height: 1,100 mm (43.3 inches)
Overall length: 2,230 mm (87.8 inches)
Overall width: 840 mm (33.1 inches)
Wheelbase: 1,500 mm (59.1 inches)
Chassis and dimensions
Frame type: Tubular steel cradle
Rake (fork angle): 28.0°
Front suspension: 41mm forks
Rear suspension: Chromed spring twin shocks with adjustable preload
Front tyre dimensions: 100/90-19
Rear tyre dimensions: 130/80-17
Front brakes: Single disc. 2-piston calipers
Front brakes diameter: 310 mm (12.2 inches)
Rear brakes: Single disc. 2-piston calipers
Rear brakes diameter: 255 mm (10.0 inches)
Speed and acceleration
Power/weight ratio: 0.3024 HP/kg
Thunder_Forever is offline   Reply With Quote
Old 10-05-2006   #4 (permalink)
5bassman's Avatar
Just what I needed. Thanks!
2005+ Speed Triple Torque Specs Devious2XS Speed Triple Forum 4 09-20-2006 08:55 AM
2005 Performance specs? wills Sprint Forum 6 09-14-2005 11:56 AM
2005 ST Price and Specs from a Dealer? 1fastcat Sprint Forum 30 09-12-2004 12:55 AM
2005 Speed Triple Brochure Specs 1fastcat Speed Triple Forum 23 09-10-2004 11:23 PM
POSTED: Official 2005 S3 Specs 1fastcat Speed Triple Forum 4 09-10-2004 01:04 PM
