dagboy,
Firstly you won't get much of a response here because its new Bonnie. Classic Vintage and Veteran is where you need to post stuff like this.
But, secondly you will get some and for what it's worth here is mine.
You should have power at the Boyer box with the key on. Check fuses and connections.
The coils are in series, if one doesn't work the oyher won't either.
If you have spark only on one pot then it's either the lead or the plug. Swap over leads/plugs one at a time.
Darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
