Check the voltage of the battery (with the ground terminal disconnected) before you go for a ride. Reconnect and go for a ride of at least a couple of hours. Retest your battery immediately afterward. If there is any significant difference, suspect something. New battery is good, but I hold to the adage that a new part is also an untested part. Always be skeptical.
