Old 09-28-2006   #1 (permalink)
LS1
Favorite Bike: 2004 Bonneville
LS1's Avatar
Other Motorcycle: 1978 CB400
How do you get to the stock inline fuel filter (not the tank filters)? My understanding is that there is an inline filter at the tee between the two carbs.
Do you need to pull the carbs to get at it?
Thanks
LS1 is offline   Reply With Quote
Old 09-28-2006   #2 (permalink)
LS1,
Disconnect the line at the T from the tank and it is there. My old one is landfill. I fitted a new in line filter. The one in the tank will go when I get a round tuit.
Darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 09-28-2006   #3 (permalink)
LS1
LS1's Avatar
So once the line is disconnected from the tee you can just pull out the inline filter?
Will try this weekend.
Thanks
Old 10-10-2006   #4 (permalink)
mt690
Since my bike has only 200 miles on it I decided to install an inline filter and checked various comments on the forum. I purchased the Pingel Filter with the bronze element which has a diameter just larger than a quarter and overall length about 2 inches. I cut the fuel line about 1 inch past the upper rear engine bracket where the preformed fuel line comes down from the petcock. I pushed the filter on ( carburetor side) and secured it with a worm drive clamp. I pulled the line going to the petcock and cut off about an inch and them proceeded to stretch it through the brackets and attach to the filter. If you postion the clamp just right it fits perfectly between the two engine mount brackets. This resulted in no kinks or restrictions and the top of the filter rests against the rear engine mount brackets. This was a great install since it could all be done from the right side of the bike.
Jim
Old 10-10-2006   #5 (permalink)
mt690
Since I the bike was so new I did not remove the filter down at the tee fitting. ( I'd probably have to remove the carbs to do that.)
Jim
Old 10-11-2006   #6 (permalink)
I checked the "stock fuel filter" (actually it is a fuel screen--not a filter) at 12000 miles and it looked like new, so I put it back in place and quit worrying. :-D
Larry
Larry
Old 10-12-2006   #7 (permalink)
SpeedyPete's Avatar
Similar to Larry, I checked the carb bowls when I re-jetted at about 5K mi and they were sediment-free so just left well enough alone.
P
I have heard the song of the Sausage Creature!
SpeedyPete is offline   Reply With Quote
Inline Fuel Filters webonnielad Twins Technical Talk 4 07-24-2007 04:43 PM
Fuel Filters Doublenikkel Sprint Forum 4 05-06-2007 08:30 PM
on fuel filters Geoff Twins Technical Talk 5 03-13-2007 09:57 AM
Did you know our Trophy's have 3 fuel filters? Mark62 Trophy 3 07-12-2005 10:08 PM
Fuel Tank paint clogging fuel filters on Adventurer Hinckley Classic Triples 3 03-09-2005 03:41 PM
