Idle Mixture Adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-27-2006, 08:32 PM   #1 (permalink)
mt690
My Bonneville is now about a week old and I did remove the AI just after I got it home. The pipes were already discolored when I picked it up with 16 miles on the odometer. No big deal. I know that the carburetors are adjusted lean to meet US EPA requirements so I ordered the carb adjustment tool to richen the idle circuits. Before adjusting I noticed there was a surging in second or third gear at lower RPM's which I attributed to the lean condition and also an occasional pop back through the carbs when it was still cold. Today I got the D Tool and checked the turns on each screw. 1 turn out on the left and 1.5 turns on the right carb. I proceeded to run each out to 2 turns. The bike now warms up much faster and no surging at the low RPM's and no more popping. I was wondering if I should go out one more half turn or just see how things proceed. By the way I'll attach a couple of photos of the pipes when I figure out how to send them.
Jim
Old 09-27-2006, 08:38 PM   #2 (permalink)
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Guzzi Griso 8v SE
Extra Motorcycle: My 1991 BMW R100GS
Here's a good read with lots of info that may be useful to you.
Jenks Tuning Guide
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
Old 09-27-2006, 08:48 PM   #3 (permalink)
mt690
Thanks, I've downloaded and printed.
Old 09-28-2006, 04:36 AM   #4 (permalink)
Main Motorcycle: My old Bonnie
doctorjay's Avatar
Other Motorcycle: Triumph Thunderbird SE
IMHO, I'd see if the carbs need balenced...build a fluid loop manometer or buy one of the mercury ones...That should put the finishing touch on the smoothness...
Thriumph Thunderbird SE 2010
doctorjay is offline   Reply With Quote
Another Idle mixture question ronbutchart Twins Technical Talk 21 01-07-2008 12:09 AM
mixture adjustment Tweekedknee Twins Technical Talk 5 07-08-2007 12:35 PM
Idle Mixture Screws itcha Twins Technical Talk 0 06-07-2007 02:20 AM
Mixture Adjustment pweitz Twins Talk 2 02-03-2006 10:35 PM
idle mixture needles entropy Hinckley Classic Triples 5 03-08-2005 09:23 AM
