On 2006-09-27, Brooksie wrote:
Hey Keef!When I talked with Brithish Customs, they went with a TON of mods, including cams and head replacement to get to 85hp, along with air box removal . Please fire over a list of your mods and I will be checking out that shop. Thanks for the input!!
...and...
Keef-you MUST show a picture of the finished bike, if she's done! I love the teardrops pipes! Great work! That's what an ENTHUSIAST looks like!!!
I'd be glad to Brooksie. First, here's a list of my mods - I don't think I've left anything out (but then I haven't had my morning vat of coffee, so I can't be 100% sure).
MY MODS (so far):
• AI removal – two SV650 sump bolts, a nipple cap for the left intake manifold and a half inch rubber bung for the top left of the air box.
• Triumph tacho kit.
• Ally custom front master cylinder cover.
• Fabbri bandit fly screen.
• Drag bars followed by Norman Hyde M bars (up-side-down).
• TORS followed by Togas – mounted on home made ally hangers and with J C Witney type baffles (opened up for free flow by having a 10mm drift hammered down through the centre).
• Wiseco 904 Big Bore kit.
• NARK – air box cut down in situ (with a dremel), K&N pod filters added and carbs mounted on two s/s brackets.
• Carb mods – 42 pilots; 130 dyno-jet mains (equivalent to about 152 to 155 normal-type mains); Kawazaki GPz900 slide springs; thruxton needles; 6 shims.
• 18 tooth sprocket.
• New s/s link plate.
• Custom license plate (made to same width as rear fender)
• Magnetic oil drain bolt.
• Fork gaiters (BMW K75)
• Hagon progressive fork springs.
• Hagon Nitro shocks on rear.
• Goodridge s/s braded brake hose on the front.
• Metzeler Lasertec tyres – front: 100/90-19V, rear: 140/80VB17
Like SCCTrim, I think I'll be needing some head work done if I'm to reach the 85hp mark - some time later, I dare say.
Oh, and here's a couple of photos I took of it a few days ago up behind the house on Caldbeck Common.
[ This message was edited by: keef on 2006-09-28 17:22 ]
