On 2006-09-20 11:24, ThruxArt wrote:
Hello everyone, I know the relocating Thruxton clip ons above the triple clamp has been discussed several (dozen) times on this forum but I'm still unclear as to how far I can slide my tubes up. I've read 17-20 mm but I've also read 1 1/8 inches (approx 28mm) I have stock tubes and springs and would like the top of my forks to be flush with my clip ons, basically, sliding my tubes 25mm. Is this possible without the fender hitting the rectifier? What happens if it does hit? I hear "disaster" but how different is that from a fork internally bottoming out? and has anyone relocated their rectifier to avoid this?
Looking forward to my new weekend project and any advice would be appreciated. Thanks in advance.
Art.
The easiest way to find out the absolute maximum, is to put the bike on a lift, with both wheels off the ground, remove both fork caps to releive any and all spring tension on the lower legs. Then care fully, remember there is still oil in those forks, push up on the wheel until it "bottoms."
At that point, have a helper measure any and all obstacles that the fender comes close to...rectifier, frame down tubes, etc.....your MINIMUM clearance figure PLUS 1/4" is about how much you can safely drop the tubes.
Now while you have help, loosen the clamp bolts and move the forks up....same procedure, 'cept this time the helper is measuring the fork leg protruding from the top clamp, and cinching things down as you get where you wanna be.
Now, with the forks lowerred, and even, side to side, shove 'em back to bottom again, and S-L-O-W-L-Y turn the forks right to left, checking clearances.....always allow at least a 1/4"...I personally like 1/2" clearance MINIMUM, as things FLEX on a motorcycle, and too little clearance, and a flexed front tube from a 100mph brake application can spell didaster if everything goes wrong.
Then reassemble......This is all, hypothetical advice on how one MIGHT check clearances...I'd never recommend modifying any motorcycles suspension....to do so can be dangerous...
[ This message was edited by: kliff on 2006-09-20 12:50 ]
