Motorcycle.com
Old 09-16-2006   #1 (permalink)
c9d9
Anybody got input on British Customs 994cc big bore or Wiseco 988cc bore and stroke kits? Anyone had it done? They must put quite a strain on the other parts like the crank, etc.
Old 09-16-2006   #2 (permalink)
Favorite Bike: 05 speedmaster - black
I have been wondering about these kits too. Why does the Wiseco bore and stroke kit cost the same as the bore only kit? Is there something else that is needed? Wouldn't it be neccesary to change the crankshaft to increase the stroke of the engine? Wiseco web site is not much help. Or am I just missing something obvious?
THe BC 994 kit seems more straight forward with a new cylinder set. Costs a lot more too.
mag10 is offline   Reply With Quote
Old 09-16-2006   #3 (permalink)
c9d9
The Wiseco comes with new conn rods that are longer and pistons that have the wrist pins higher up the piston. The conn rods are going to be off-center of the wrist pins to account for the oversize bore, especially in the 994cc kit from BC. I wonder if the pistons have a tendency to crack in the long run because of the load on the pins being off- center?
Old 09-16-2006   #4 (permalink)
Retired Legend
sweatmachine's Avatar
The wiseco kit DOES NOT come with connecting rods...you'll have to have your crank stroked and pulling it means basically a total engine rebuild...$$$$$
the BC 994 kit requires splitting the cases, and machining them which also means engine rebuild...
how fast do you want to spend?
I think the logical (can I call it that?) approach is:
904 kit (wiseco or BC)
cams (BC or thunderbike)
carbs (ask Dinqua)
aftermarket CDI (BC)
port/polish heads
with all the exhaust and intake goodies, this package should make a solid 90rwhp, and probably 75ish ft-lbs at the wheel, and be quite the lively performer without having to do an engine rebuild, other than a top end job.
cost? hehe
alright alright alright
Bonnie cafefighter!
Old 09-16-2006   #5 (permalink)
Retired Legend
and jojje gets 200 plus hp out of his turbo'd drag bike, I think the crank can handle 90 just fine.
Bonnie cafefighter!
Big bore kits, mpg & rear tyre wear Old Scratcher Twins Technical Talk 30 11-23-2007 05:39 PM
Carb Settings for 904cc Big Bore Kits ggRAT Club Cafe 1 10-23-2007 03:05 PM
big bore kits 69bonney Twins Technical Talk 18 12-16-2006 04:20 PM
Big Bore Cafe for the big Dude... Thrux-ton-up Club Cafe 8 10-15-2006 12:10 PM
Big bore kits and vibration triumphgeezer Twins Talk 6 04-15-2006 06:55 PM
