Muffler Autopsy - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-07-2006, 01:19 AM   #1 (permalink)
Main Motorcycle: 1972 Suzuki TM 250
Loxpump's Avatar
I've done the bafflectomy and drilled through the internal baffles but have always wondered what is inside. Well here it is. I had an old set off my 2002 Bonneville that were of no use so I ripped one of them down the middle to have a look.
1st. picture before:
Don't look any further if you are at all squeamish at the sight of rust and fiberglass.
Now I know why they are so quiet. The exhaust has to goes through a maze of 5 chambers and baffles.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 09-07-2006, 03:38 AM   #2 (permalink)
Main Motorcycle: 2011 Roadster Gloss Black
Other Motorcycle: 2001 Bonneville 32000km
Now that answers a lot of questions. Great photos that will most likely stop the need to for any more baffle removal posts. You should be congratulated.
2001 790, A1 removed, K&N Air filter, restrictor plate removed, air box intake cover enlarged, stock needles 2 shims, 130 mains, 42 pilots, NH Classic Toga Mufflers - no baffles, Twin Power remap stage 1, 19T, NH Western bars, Dart flyscreen.
Motolink is offline   Reply With Quote
Old 09-07-2006, 05:32 AM   #3 (permalink)
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Guzzi Griso 8v SE
Extra Motorcycle: My 1991 BMW R100GS
Ya shudda been a surgeon! These photos could be the supporting visuals for a thesis on bafflectomies. Or something ............
Good job!
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
Old 09-07-2006, 05:47 AM   #4 (permalink)
Fantastic work.
Questions...
At the inlet end, the tube inlet almost looks shiney. Is it just the photo or is there something in that first inlet tube?
What are the two round "bosses" I see in the 2nd expansion chamber? (I'm assuming they are for the mounting bracket bolts)
I wonder why the middle "baffle" has the "Y" type arrangement and why would they do it perpendicular to the rest of the baffle?
Thanks very much for the time spent showing us this.
Colin
Colin_In_Ottawa is offline   Reply With Quote
Old 09-07-2006, 06:48 AM   #5 (permalink)
Loxpump's Avatar
Some of the pictures were taken after I tried to clean off some of the black carbon with brake cleaner. It was just still wet. When I was taking the pictures they looked all black on my cameras little screen, so I thought it needed some contrast to show up better. I saw that "Y" in the one pipe also. Not sure about that either. It still ends up being basically about a three quarter inch pipe for the exhaust to flow through. And the two bumps are covering the nuts that are welded on the inside for the bracket bolts. Which was a problem when I took these off. One of the bolts was rusted on so bad that it broke the weld loose on the inside of the muffler and I had to grind off the head of the bolt to remove the bracket. It happened on both mufflers.
Semper Fi!
Old 09-07-2006, 07:14 AM   #6 (permalink)
wonderdog's Avatar
Great pictures, thanks!
I've wanted to do the basic baffelectomy, but hesitated as I couldn't see exactly what I would be bashing even with the good baffelectomy pics. Your pictures cleared all that up.
Great job, thanks again!
Dennis
Eggs and bacon. A days work for a chicken, a lifetime committment for a pig.
wonderdog is offline   Reply With Quote
Old 09-07-2006, 07:28 AM   #7 (permalink)
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Good work! No wonder they are so restrictive. Glad mine are in a box, not on the bike...
Old 09-07-2006, 08:50 AM   #8 (permalink)
Main Motorcycle: 2001 Bonnie, 2011 T800XC
Other Motorcycle: 2003 Honda XR650L
Wow. No wonder they make the bike sound like a sewing machine.
I wonder what TORs look like inside. Maybe I'll cut mine open when I've replaced them (they're rusting anyway, so no point in reselling).
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 31-June 2, 2013
markbvt is offline   Reply With Quote
Old 09-07-2006, 09:26 AM   #9 (permalink)
Loxpump's Avatar
Mark, It would be a good comparison. Don't they look about the same, size and shape wise? It was really easy to do, just need a band saw with a metal cutting blade.
Semper Fi!
Old 09-07-2006, 09:47 AM   #10 (permalink)
Main Motorcycle: 2006 Bonneville T100
Ridge's Avatar
Other Motorcycle: '76 Bonneville T140v
Extra Motorcycle: '71 Honda CL350
Ah! Very ccol, Lox! I always wondered what went on in there.
How bout a cut-away of your engine next? :
Ridge is offline   Reply With Quote
Two Tone Muffler chedd Twins Technical Talk 12 12-31-2007 04:11 AM
Muffler Meat drharveys Biker Hang-Out 21 12-18-2007 01:57 PM
muffler poll bricktop Twins Technical Talk 44 04-12-2007 11:20 AM
2002 CF Muffler motogeezer Sprint Forum 3 10-06-2006 05:35 PM
muffler disaster JonCG Twins Talk 5 08-30-2005 06:28 PM
