» Links |
09-04-2006
Formula Extreme Favourite Bike: 2006 Triumph Bonneville T100
Posts: 615 Other Motorcycle: 2006 Triumph Scrambler
I hope someone can advise me about a vibration issue with my new 2006 Bonneville T100. The bike is currently stock with 1,300 miles total, (except for the oxygen sensor removed), and at speeds over 70 mph, the rear end develops a very noticeable vibration that increases as the bike speeds up. At 80 mph, which this bike should be able to do with no problem, and in my opinion with less vibration, I can feel the seat and particularly the rear end buzz and vibrate a lot. Up to 70 mph, the bike runs smooth with little or no vibration. It's just that going 80 mph or more results in a level of vibration that should not be present with a new bike with new tires, in my opinion.
The rear tire's air pressure is correct at around 32 - 34 psi, and no balancing weights have fallen off the rear rim (assuming Triumph correctly balanced the rear wheel at the factory). Also, the chain tension appears to be OK, and the left and right side rear tire alignment indicators seem to be at an equal setting. There are no broken, loss or missing rear spokes as far as I can tell.
Should I get the rear tire pulled to see if it is balanced correctly? Or perhaps the rim is defective or "out of round"? Perhaps a wheel bearing is bad? I need to adequately describe the problem to my dealer so his mechanics will take the trouble to check it out.
When I bought the bike new, the first 1/2 mile of riding identified a defective front rim (offset weld), as the handlebars shook a lot and the front wheel hopped quite a bit. Fortunately, when I went right back to the dealer, the diagnosed the problem and swapped another new front wheel and rim off another T100.
Any advice would be much appreciated. :???:
[ This message was edited by: Scrambler900 on 2006-09-05 16:36 ]
Stay cool, like Steve McQueen
I don't know what tires your bike came with, but on my 05 T100, the OEM Metzler MEZ2 rear tire calls for 38 psi. If indeed your rear tire calls for 38 and you've been running it 5 lbs low, the tire could be damaged and dangerous, thus the vibration.
2005 T100
09-04-2006
The last time I was in the dealership the service manager gave me a pressure guage with 36# front, 42# rear printed on it. I remember when I bought my T-100 he also mentioned it then. That is the pressure I try to maintain. I did ask if the 42# was high, as that seemed a bit high to me, but he claimed that for our altitude it is just right.
Robert
Robert
Riverton, UT
2006 Boneville T100, Triumph Fly Screen, Triumph Sixty8 Contemporary Seat, Triumph Seat Cowl, Triumph Gaiters, NB Clutch Dressup Kit, AI Removal, Bellacorse Fork Stem Clock, Triumph Saddlebags, Renntech Engine Guard
09-05-2006
SuperSport Favourite Bike: 1966 Bonnie
Posts: 1,082 Other Motorcycle: Malvern Star
I think you should be checking the wheel balance.At the speeds you are talking about,that is the range where the resonance from the rear shocks and an unbalanced wheel will co-incide causing vibration.
I spent 5 years as a front end technican,end fiont end vibrations will nearly always occur below 60 mph and rear above.
The tyre may have been deflated at some stage and rotated on the rim causing it to be out of balance,has it had a flat tyre?
Or it may have just been done late on Friday arvo when the production worker was in a hurry to knock off.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
09-05-2006
Team Owner Favourite Bike: 2003 T100
Posts: 4,405 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: 2008 Guzzi Sport 1200
Amanger - could you elaborate a bit more on the shock resonance/unbalanced rear tire thing? My T100 is fine, but I'm going thru a similar problem on my W650. I'm having a hard time determining whether it is front or rear end.
I just installed new GT501s on the W, and am experiencing vibration anywhere over 60-65 mph.
I tried to isolate it by (a) reaching forward while riding and feeling the lower fork leg .... can't tell if it's road vibes or out of balance. Also reached back and put hand on rear shock spring .... seemed to be pulsating, even at slower speeds.
When I got home, I put bike on center stand, in 5th gear, and ran it up to approx 60mph, with no apparent vibration.
I'm going to try to ck the front wheel balance without pulling the wheel. I will pull the brake caliper, and spin the wheel several times and mark it to see if it stops at the same place, but don't know if the front wheel bearings spin freely enough for this test to be valid.
Shocks are the originals that came on the bike from the factory, with over 50K on them, which could be the problem. I'm ok with the ride, but the shocks are probably worn out, or at least not responding properly to normal small road irregularities.
Any thoughts will be appreciated.
NOTE - the W seems a lot more sensitive to minor wheel and tire irregularities than the T100.
Bob
03 T100 Lucifer Org and Silv: 122/42 jets, TORs, 17T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Progressive 440 shocks (105/150 springs), Intiminators, Thrux fork caps, gaiters, MotoTwin low bars, 6024 lamp, htd grips, 12v outlet.
09-05-2006
SuperBike Favourite Bike: 05 Black Speedmaster
I disagree, sorry. I don't think 5 LB low would be a serious problem at all.
09-05-2006
All coil springs have a resonance rate.That is they vibrate at a certain rate much like a musical tuning fork.It is only when the wheels are rotating at the same speed as the spring is resonating that you will feel an unbalanced wheel.
I m not sure of the physics behind it all,but front suspension springs resonate at a lower pitch (speed) than rear,which is why you feel an unbalanced front wheel in the 80-100 km/h zone and rear usualy above 110 km/h.
09-05-2006
Thanks fellas, for this good advice, and I will check out my bike according to each recommendation.
09-05-2006
Thanks, Amanger,
Bob
09-05-2006
SuperSport Favourite Bike: 2003 Triumph T100
Posts: 1,207 Other Motorcycle: 2007 M-G Cali Vintage
Just a couple more suggestions: Check the rear wheel alignment, the tension of the spokes, and the torque on the swingarm pivot. In the old days these were common culprits for bad handling characteristics.
