Old 09-04-2006   #1 (permalink)
Am wanting to change my sprocket from the stock 17 that comes on the TBA to the 19 tooth that they have on new speedmaster.com. If I do this, do I need a new chain? Or will the original chain still fit with the new sprocket? Also how involved is it to change these out? Any special tools needed? etc. Doesn't seemt that it should be too difficult, but I'm no mechanic. Any input would be awesome. Thanks guys!
dseely is offline   Reply With Quote
Old 09-04-2006   #2 (permalink)
Other Motorcycle: 66 Bonnie Chop
Here's an excellent how-to from Dinqua that explains everything with photos. You'll need a 24mm socket, Sears has a lot of their weird sizes on sale cheap right now (usually about $10).
Dinqua How-To - Sprocket Change
Your chain should be fine.
Al
ssjones is offline   Reply With Quote
Old 09-04-2006   #3 (permalink)
As an adendum to Pat's site, a lot of guys are just using the rear brake to hold the chain steady while they crack loose that nut, rather than the block of wood trick... I am old school and used the wood
Pack Leader, LINY RATs
'02 Black Bonnie America
Anyone on long island?
bennybmn is offline   Reply With Quote
Old 09-04-2006   #4 (permalink)
thanks guys!
Old 09-04-2006   #5 (permalink)
Favorite Bike: 05 Black Speedmaster
Pretty sure that socket was 36mm ?
Old 09-04-2006   #6 (permalink)
Correctamundo. a 1 7/16" also works.
Pat Whitbeck
Canandaigua, New York 14424
Dinqua is offline   Reply With Quote
Old 09-04-2006   #7 (permalink)
LT
Favorite Bike: '05 America
LT's Avatar
Other Motorcycle: '93 BMW R100 RT
David- You may want to try an 18 before the 19. 18 for me was a little tall around town, saving it for trips.
LT is offline   Reply With Quote
Old 09-05-2006   #8 (permalink)
Favorite Bike: The one I ride of couse..
Other Motorcycle: but then the Speed 3
Yeah it is a 36mm socket...and I would definitely try the 18 tooth first. You lose a lot of low end torque. I switched to the 18 tooth but I would not go any higher, unless you just like puttin around like a Hardley rider.
Check out my Pics!!
My Bad A$$ Bike!!!
gm16sw is offline   Reply With Quote
Old 09-07-2006   #9 (permalink)
Not sure why I put down 1 & 7/16" and 24 MM in my maintenance worksheet. Does a 24 mm socket fit the rear axle nut?
Al
Old 09-08-2006   #10 (permalink)
Yup. If I recall, the left and right sides of the rear are different sizes so you don't need two of the same tool.
tips on changing front sprocket awegs955i Daytona Deliberations 1 08-03-2007 11:16 AM
Changing the sprocket Blacklion50 Twins Technical Talk 1 05-17-2007 09:50 AM
front sprocket changing Binnsy Twins Technical Talk 12 03-27-2007 02:30 AM
chain and sprocket changing oldyeller Daytona Deliberations 7 11-11-2006 02:07 AM
Question about changing counter-sprocket NinjaRAT Sprint Forum 6 09-19-2005 09:13 AM
