Airbox question - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearMotorcycle.com Classifieds!Honda Powersports
Old 09-03-2006, 03:23 PM   #1 (permalink)
stu
Favourite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 1974 Commando
With the snorkel and baffle out, I calculate the opening of the Unifilter is around twice that of the carb body. I guess I don't understand why it is necessary to cut chunks out of the box or NARk to get more performance.
Stu
TORs, NARK, thruxton needles, 140mains.42 pilots 1.5 turns out, procom igniter, 19T
stu is offline   Reply With Quote
Old 09-03-2006, 04:14 PM   #2 (permalink)
Stu,
I don't know either. It must be due to having an uninterupted path. The path through the airbox is neither straight or smooth.
Darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 09-03-2006, 06:43 PM   #3 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Bonneville
Today I removed the restrictor plate. Took my bike for a ride,...seemed to be breathing better, smoother,...better charge to limiter,...won't idle even when warmed up !???,... 1/2 turn on idle adjustment,...rock solid at 800rpm. Better than before,...always had a slight stumble, now perfectly even. Haven't went for a ton plus ride yet. I'll tell you what happened. TOR's 125 main jets stock needles, 18thou shims on needles, "Tony's Rocket Fuel"* fuel mix.
* Trade Secret
Asphalt is My Airbag
2522 is offline   Reply With Quote
Old 09-04-2006, 07:07 AM   #4 (permalink)
I'd hoped to get by with mods similar to yours. Yes the torque curve smothed out and I got 8hp more at the wheel. Not enough though. I agree - it's probably the flow path - it's really higgly piggily! I did spend some time trying to align all the bits and bobs but I'm chucking the airbox! There are few complaints from those who've gone this route.
setts is offline   Reply With Quote
Old 09-04-2006, 07:15 AM   #5 (permalink)
reido113
The hole in the airbox will reduce your chance of blowing it up from one of those seat farts..
Old 09-04-2006, 09:31 AM   #6 (permalink)
Got a little creeping of color along my pipes,...I've got to RE-JET!!!! I guess it's a little lean. Thought it might be. Just means there was considerable restriction with that plate in the air box. Now with it gone, I'll just have to mix a little more fuel with that improved flow. Off to buy jets.
Airbox question....again? 2ManyToys T3 Sport / Touring Forum 14 02-15-2008 08:03 PM
Airbox question itcha Twins Technical Talk 2 01-24-2008 06:23 PM
95 Airbox question patrol21 Hinckley Classic Triples 2 12-11-2007 09:08 AM
another oil in airbox question johntog Twins Technical Talk 3 08-12-2007 12:18 PM
Airbox mod question AVM Tiger Mods & Bolt-Ons (archive) 4 07-15-2005 06:26 AM
