It may run ok, but its likely lean and running hot.
I thought the TOR's were to quiet, and they were, till I fit the dynojet kit and removed the snorkle.
The dynojet kit has softer slide springs, which allow more throttle openings at any given RPM, and that along with the snorkle removal allows more into the engine, so you get more out (louder exhaust).
It sounds just how I want it to, not to loud, not to quiet, and MUCH better power between 2500 and 4000 rpm.
Brett
