Center Stand - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-31-2006, 09:07 PM   #1 (permalink)
I'm looking to purchase an after market center stand. Does anyone know other than Triumph who sells the stands? Also....what where your experiences installing the stand including the one offered from Triumph.....
Thanks all!!!!
kickenash is offline   Reply With Quote
Old 08-31-2006, 10:29 PM   #2 (permalink)
Favourite Bike: 1972 Suzuki TM 250
Loxpump's Avatar
Installing the center stand is easy. I just put one on my 2002 bonnie. It came off my wrecked 2001. One thing that made it easier is to keep the stud that holds the "C" bracket loose, until you get the double spring hooked on thole in the stand. It allows a bit more slack and you don't have to pull the double spring quite as far to hook it. Then tighten the nut holding the stud. I don't know about any other maker of center stands.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 09-01-2006, 11:25 PM   #3 (permalink)
On 2006-08-31 20:29, Loxpump wrote:
......... One thing that made it easier is to keep the stud that holds the "C" bracket loose, until you get the double spring hooked on thole in the stand. It allows a bit more slack and you don't have to pull the double spring quite as far to hook it. Then tighten the nut holding the stud. ...........
DAMIT DAMIT DAMIT! Why didn't I think of that!!??
I ***** near lost two fingers and a testicle stretching that ***** thing on!
Maximalist
Ramjet is offline   Reply With Quote
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 03:53 PM
Kick Stand vs. Center Stand Tooth Maintenance & Workshop Talk 9 10-19-2005 10:02 AM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 07:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 09:38 PM
