Hmm,
Let me guess you have the dreaded M-Bar vibes.I solved the problem by hammering lead fishing weights up the bar ends then drilled a small hole through the lead to put the 5mm bolt through.I then bought a nice set of after market barend weights made for 7/8 bars and got a long enough 5mm bolt from the hardware store to screw into the stock retainer.
Anyway with about a kilogram of weight on each end the problems solved.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
