AdvanstarMotorcycleShows
Old 08-27-2006   #1 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
When one of our forum members has what appears to be a carburetion problem, I don't think I can recall seeing any solutions that recommend checking the fuel level in the floats. Every possible jetting solution is proposed. I've noticed that bikes equipped with identical or nearly identical jetting and exhaust as mine exhibit really bad operating characteristics, while mine is running perfectly.
This makes me wonder if, during the initial rejetting process, particularly float bowl replacement, the floats on some of the bikes are disturbed enough to cause fuel levels to be off? Maybe the float tangs have been bent, etc?? Especially on bikes that are rejetted with the carbs left on the bikes?
Anyone have any thoughts on this? It may be a blind alley, but ............
Bob
Old 08-27-2006   #2 (permalink)
Favorite Bike: Triumph Bonneville (of course)
doctorjay's Avatar
Good idea...when I re-jetted I had ahellova time putting the bottoms back on...then I realized that the float tangs were sticking out alittle...when put back in so the hinge worked...everything snapped back on just fine. I did re-jet with the carbs on and tilted at a 90 degree angle and thats how those darn tangs slipped out alittle.
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, Progressive 440 HD shocks, sissy bar, summer wind screen, union jack brake resevoir
doctorjay is offline   Reply With Quote
Old 08-27-2006   #3 (permalink)
Good point I had forgotten that I lowered mine 1mm on the advice of dyno operator (to lean out a bit mid range) after the second dyno. Both were at factory spec 17mm haynes say 16-18 mm. I might go another 1 mm lower.
Definitely worthhile checking if your having problems.
Much easier with carbies off which is not easy with stock mairbox.
darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 08-28-2006   #4 (permalink)
This is most critical, because if your float/fuel levels are incorrect or inconsistant from carb to carb - all your time spent jetting was really for nothing. A very good point to keep in mind. JCW
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 08-28-2006   #5 (permalink)
Ha, funny that this topic should come up.
I was just mentioning to my Dad that I was thinking about rejetting the Scrambler because I thought it was lean as received from the factory.
Then Dad starts going on about "back in the day, we used to adjust the float to make her a little richer or leaner." :???:
justice is offline   Reply With Quote
Old 08-29-2006   #6 (permalink)
ohiorider's Avatar
Checking fuel level looks like a no-brainer, based on the instructions in the Haynes Manual. Doesn't require removing float bowls, unless the level is off and the float tangs have to be adjusted.
Float height DaleE Hinckley Classic Triples 8 02-17-2008 03:06 PM
Mikuni float height buxtonmick Hinckley Classic Triples 7 11-22-2007 12:15 PM
Float level and AF mix? mshelton Twins Talk 4 03-14-2007 08:24 PM
Float Height Panthermark Twins Talk 15 03-09-2006 09:21 PM
Float level / Fuel Level for 1998 Trophy 900? CharlestonRider Trophy 8 06-04-2005 04:07 PM
