Old 08-20-2006   #1 (permalink)
Is it normal to have some valve (noise) ticking with a 04 Speedmaster? Pretty much with the stock pipes...the only thing you could hear was the valves ticking! :???:
Matrix04 is offline   Reply With Quote
Old 08-20-2006   #2 (permalink)
Mine has a tick that its had since it had 0 miles on it so Im assuming its normal engine noise.
SpeedmasterDale is offline   Reply With Quote
Old 08-20-2006   #3 (permalink)
Yes, its very normal. The tappet noise you here is the from the cams rolling over the valve shims. As they are very high on the engine and covered with thin cam cover you will always here it.
Generally it gets a bit louder when the bike is really hot. The noise itself doesn't mean your shims are out.
The green ones are faster.
satxron is offline   Reply With Quote
Old 08-20-2006   #4 (permalink)
I hate it, but it's normal as they said already. I was wondering if it could be subdued by having the inside of the cam cover coated in some sort of rubberized coating, that is if theres anything that would be impervious to heat and assuming it wouldn't cause overheating. I heard HD or some other brand uses some sort of insulation for that. It's one of my few major dislikes about the bike. luckily tho i use ear plugs most all the time for wind noise mainly, so i only really hear the pipes. I'd ride w/o them tho during slow city riding occasionally if not for the valve noise. But pulling away from a stop, especially uphill actually sounds embarassing ! Like a bucket of bolts strapped to the back of a bucking bronco. :-D
I really wish triumph would redesign it somehow and add EFI so that it's quiet and has about 10 more HP. I'd trade mine in tomorrow.
Old 08-20-2006   #5 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
It's all part of the unique character of the bike.
My Speedmaster runs like a top. A darn fast top. :-D
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 08-21-2006   #6 (permalink)
Normal Triumph sound.
And, it should subside a little as it warms up, since the valves heat up and everything expands, if it gets louder, you may need valve adjustments.
If you live in hot areas, using 20-50 oil helps some too with the noise.
I don't worry about it at all. I've had it apart many times and nothing is worn.
Pat Whitbeck
Canandaigua, New York 14424
Dinqua is offline   Reply With Quote
Old 08-21-2006   #7 (permalink)
That is a big relief! I was getting worried about the noise.
Thanks for all of the feedback!
Old 08-21-2006   #8 (permalink)
Gets louder for me, then again we have a cold front moving through. Only 101 today lol
Old 08-28-2006   #9 (permalink)
jimmything's Avatar
yea, but it's a dry heat....right!! :-D
2006 black Speedmaster with Epco pipes, 130 mains, snorkel and AI removed, UNI filter, drilled airbox, Corbin solo seat.
"Ride it like you stole it"
jimmything is offline   Reply With Quote
Old 08-28-2006   #10 (permalink)
LT
Favorite Bike: '05 America
LT's Avatar
Other Motorcycle: '93 BMW R100 RT
How many miles on it? I just did my 12,000 mile valve adjustment and its quieter than its ever been. Had 4 too loose. Still makes noise, just not as much.
LT is offline   Reply With Quote
'99 ST Valve noise Colby Sprint Forum 4 12-28-2006 10:49 PM
valve noise johnnypence Classic, Vintage & Veteran 12 06-11-2006 09:06 PM
Valve or Injector noise? Chillerguy Sprint Forum 8 06-10-2006 06:20 PM
955i valve noise dwheelie Daytona Deliberations 3 05-01-2006 09:55 AM
Valve Tapping noise ErwinM Twins Talk 6 08-15-2005 04:46 PM
