BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 08-19-2006   #1 (permalink)
I dont like them.
But for free, you can't beat them. They are a simple 2" angle, some gussests for looks, some 7/8" thick walled conduit, and some 7/16"-20 all-thread.
Oh and some old Harley pegs that I got from the back room at California Performance Iron in Vallejo, CA. One of the custom chopper builders rummaged around in his junk pile and found me a set. The clevis extensions are pretty beat up and the chrome is flaking off but if I end up keeping this setup, I will have them re-chromed. The end of the pegs have a harley logo but I am going to change the pegs anyway.
Here are some images that sort of explain themselves. The first pic is how I received the pegs. The last pic show the peg folded up. I aligned the folded pegs to be paralell to the headers for asthetics.
Click to enlarge:
-Todd
Maximalist
Ramjet is offline   Reply With Quote
Old 08-19-2006   #2 (permalink)
Are they comfortable?
John
vol245 is offline   Reply With Quote
Old 08-19-2006   #3 (permalink)
Wont you melt your shoes/boots on the pipes?
Brett
bgaz is offline   Reply With Quote
Old 08-19-2006   #4 (permalink)
Favorite Bike: Triumph Bonneville (of course)
doctorjay's Avatar
I'm interested in this modification...Great Bay has highway pegs for >200 bucks...No way I'm paying that for pegs....Can you post a easy to follow guide on how to maks these...or if you don't like them...PM me.
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, Progressive 440 HD shocks, sissy bar, summer wind screen, union jack brake resevoir
doctorjay is offline   Reply With Quote
Old 08-19-2006   #5 (permalink)
John,
No, they are not comfortable enough for my stubby legs. I am 5'9" on a good day. It might be comfortable for someone taller than me. On long rides, my legs cramp up on the stock pegs so these will be a good way to safely stretch my legs and not put the bike out of balance at freeway speeds. However, I need them about 1.5" closer to me to leave my feet on them for any legnth of time. I only made these like this because it was all made from junk parts I had. If I were to do it again, I would bend a mustache bar and use store bought clevises. Today my tubing bender is, well, out of town.
Brett,
No, my boots and ankles are actually a safe distance. The total width from end to end is 29" and by boots are well clear of hot pipes.
Doc,
I could post a step byb step, but if you know how to weld, then you should be able to figure it out by the pictures. The thing is, I bodged it together with stuff laying around my garage. Any measurements for width will completely depend on what kind of clevis mounts you have to start with.
A couple of points that will make any fabrication of highway pegs on a Bonnie go well:
1. A piece pf 2" angle about 2-1/4" long is a perfect base. You can drill to match the holes in the stock cradle stiffner plate (see second picture above).
2. 28" to 30" is a safe width for header clearance but the wider it is, the goofier it looks.
I can answer any specific questions. I can even post CAD drawings if you like but, again, mine is going to be different than anyone elses unless they can find some Sportster pegs.
-Todd
[ This message was edited by: Ramjet on 2006-08-19 18:41 ]
Maximalist
Old 08-19-2006   #6 (permalink)
bonnevillebilly's Avatar
Ramjet
Nice job from junk laying around.
I am STILL!!!!!! waiting for my pegs to arrive.
I have my bar done and mounted on the bike.
I also found mounting them up front of the down tubes
way to far away. I mounted mine to the engine mount
through bolt. They are just right with my foot resting on
them and my knees slightly bent.
I am very happy with mine. I hope my pegs will arrive on
Monday. As soon as I have them mounted on the bar
I will shear some pic's.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 08-19-2006   #7 (permalink)
I am 6' with a 33" inseam. A long time ago I owned a 1977 Suzuki GS750 and I put case savers on it. The case savers came with foot rests that bolted onto them. I put them on and never could get comfortable using them for more than about 5 minutes. They were too far away.
I felt I was slouching too much with the stock handlebars on the T100 so I put M bars on it. It is not very comfortable to me with the pegs in the stock locations while using the M bars. I use the passenger pegs whenever the traffic situation allows. I'd like rear-sets, but am not going to spend $400 on them.
I have a feeling if I put the stock handlebars back on with highway bars that the highway bars would either be too close or too far. They need some adjustability to these things.
I really only use my bike for commuting (33 miles each way) so I'm fine with it as it is. I have gone 160 miles in a day before on it and found it pretty darn uncomfortable. That trip was with the stock handlebars and I've done it 3 times. Oh well, it's not a Gold Wing.
John
Old 08-19-2006   #8 (permalink)
John,
I commute 100 miles a day on mine. I need to figure something out. My numb hands are worse than my stiff knees.
Billy,
It's time for me to say, "DOH!" I did not even think about using the lower motor mount. Now that you mention it, I notice it is a through bolt. ACK! That is the perfect location and these harley clevises are probably long enough to just stick out from there. Heck, I could do this without welding anything.
Do you know what size bolt is in the lower mount? is there any rubber in the thru hole?
-Todd
Maximalist
Old 08-19-2006   #9 (permalink)
I used a 9/16" hole. I don't know the metric size of the
bolt , but it measures about 1/2". It is a clean shot through
no rubber. Mine had a bit over a 1/4" extra thread.
Wait to you see the bar I made . 3/4" Ø stainless steel bar
and I had the clevis machined from 1" Ø s.s. bar.
Then welded a couple of 10 ga. s.s mounting plates on.
I polished them up to look as good as chrome , if not better.
I hope to have some pic's by Monday night.
Bill
2001 Bonnie
1976 Bonnie
Old 08-19-2006   #10 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
Really nice job on those pegs Todd. I love that home made stuff. They look nice and clean.
Bryan is offline   Reply With Quote
Highway Pegs snuffcityrider The Rocket Science Forum 4 11-15-2007 09:05 PM
Highway Pegs Tiggs Twins Technical Talk 13 10-29-2007 11:33 AM
highway pegs rodmo1 Hinckley Classic Triples 14 06-09-2005 12:37 AM
Highway pegs Trophy 5 08-09-2004 09:15 PM
Highway Pegs Modifications & Workshop Talk 3 09-24-2002 07:58 AM
