Old 08-08-2006   #1 (permalink)
I just ordered tires and the metzler that the manual shows as the rear is 170/80H-15 while the order i placed shows the rear as 170/80HB-15. Anyone know what that extra "B" is for? I'm thinking maybe "blackwall" or some such thing, while the "H" is an actual generic designation for some aspect of the tire size.
Old 08-08-2006   #2 (permalink)
KuzzinKenny's Avatar
everything you ever wanted to know about tyres !! Clicky !!
have fun !!
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is online now   Reply With Quote
Old 08-08-2006   #3 (permalink)
Nice. I have it bookmarked, tho i still couldn't find the answer to the question. Anyone ?
Old 08-08-2006   #4 (permalink)
Hey daz.
I am pretty sure that the "H" designation in the manual is just the "conventional" tire sizing - H15.
After much fannying around on the Metzler site, I have determined that the "B" code preceding the tire diameter is in fact the construction code. According to [THIS] .PDF file of their 2006 tire range, the "B" construction code means "BIAS BELTED".
Bias Belted tires are constructed with a conventional carcass and a belt made of one or more crossed layers. The difference between carcass and belt is given by the different goals that they have to fulfil and consequently the different materials that are used: the belt is mainly made by Nylon and has to reduce the dynamic deformation due to the centrifugal forces, while the carcass has to mainly give the tire its contour.
You can read a lot more on the tire markings [HERE] daz.
Cheers; Paul.
You can take a look at my bike HERE!!
truebrit is offline   Reply With Quote
Old 08-08-2006   #5 (permalink)
170/80HB-15
170: Width in MM at the widest point.
80: Ratio of height to width, i.e it's 80% as high as it is wide 170*.80=136mm
H: Speed rating, I believe H is up to 114mph
B: Construction, B=Bias, R=Radial
15: Diameter of rim.
Geof
[ This message was edited by: abruzzi on 2006-08-08 17:25 ]
abruzzi is offline   Reply With Quote
Old 08-08-2006   #6 (permalink)
Ok, so the B is for bias belted. I looked at the original tire and it does have a B in it, but it's not arranged the same. It says "170/80 B15 m/c 77H".
The m/c of course means motorcycle but what is the 77 and does the B mean the same thing even tho it the H and B are not together and right after the 170/80? i just want to determine id the tire i bought is exactly the same or if they changes the plys somehow. Come to think of it, it did mention the plys on the tire but i don't recall if it mentioned steel, but it did mention nylon. Soulda brought a pencil out cuz it was all i could to to remember the tire size and rating specs.
Old 08-08-2006   #7 (permalink)
Ahh....i see the 77 is the load index code and the B should be just asyou guys said no matter where it's located. it's just that ther arrange all these codes differently in the string on the tire then they do on paper.
Thanks all. now i can't wait to get them on and be over with all this. should have em by the weekend if the place is as fast as they say they are.
Old 08-08-2006   #8 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
Speaking of Metzelers, do they make a whitewall for the Speedmaster? Maybe that's too over the top?
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 08-08-2006   #9 (permalink)
i think they do. When i was looking at them one of the sites showed a whitewall option, tho i don't know which tires that are offered with that. maybe all, maybe a few. Go to metzler's site and you should be able to find out for sure and email them if need be. I don't want whitewalls, but i sure wish they offered the white lettering like dunlop does. that looks very slick.
Old 08-09-2006   #10 (permalink)
Redlines would look sweet on a black speedmaster. Don't know if anyone makes redlines for bikes (they were standard equipment on some of the old Triumph four wheelers, i.e. cars.)
Geof
Metzler Z-6`s Doublenikkel Trophy 6 07-24-2007 09:59 PM
Metzler M3 Update 2K and Done!!! keo1050 Sprint Forum 27 05-10-2007 05:38 PM
Metzler tires... kliff Twins Technical Talk 14 04-05-2007 03:03 PM
Metzler LaserTec Panthers_Den Sprint Forum 2 11-13-2005 01:09 PM
Designation for 95/96 model Speed Triple Forum 2 10-22-2004 05:21 PM
