I took my T100 in for 500 mile service yesterday. Last night, I rode it all up and down PCH and I-5 South from Orange County to San Diego. It was fine. It ran well and had plenty of power. This morning, I rode it back to work.
About five minutes into my ride, I stopped to get gas. I filled up (but not overfilled) and got on the freeway. I worked up to about 70-75 mph. After maintaining this range of speed for about 30 seconds to a minute, my fuel started cutting out.
I would start to feel weakness followed by surging, and then more weakness. I would pull in the clutch and rev the engine, but it wasn't a clean rev. It was just a messy burble. I pulled over to the side of the freeway and put it in neutral. It was idling sub-1000 RPM. After about 15-30 seconds, I would slowly roll on the throttle and it would be a clean rev again.
I pulled onto the freeway slowly and worked my way back up to 60 mph. All seemed fine, but after about a minute on the throttle, it would start to cut out again. I would pull over and repeat this process about eight or nine times on the way from Solana Beach to Orange County. I found that if I pulled in the clutch or rolled off the throttle regularly, I could go without the fuel seeming starved. Eventually, it
mostly cleared up, with only one repeat occasion after riding around 80 mph for a couple of minutes.
I took it to the dealer. They looked at the carbs, fiddled with some stuff and took it for a ride. The mechanic said he could not repeat the problem, but that a few others had come in with a similar issue. One theory was that the EPA charcoal cannister accumulated gasoline fumes overnight and was messing with something. :???:
Another theory was simply that the flow of fuel was being inhibited slightly, causing the bowl to fill and allow me a minute or two of clear riding following by the repeated coughing fits.
Whatever it is, I don't like it. Especially not on a new bike.
