I'd buy a Haynes manual, and go for it. What a dealer should do at the 500 mile mark, in addition to oil change, is basically go over the whole bike to check for anything loose, check chain tension, check free play in brakes and clutch, check wheels for loose spokes, and then a test ride to see that all is well. This is all easy stuff you should get used to doing your self, maybe once a month, and your wheels wont fall off, or other embarrasing and potentially dangerous situations wont bite you
Geoff
I just wanted to ride
