polaris bell-mouth-phase 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGear
Old 07-05-2006, 08:27 AM   #1 (permalink)
I put one in. I saw a thread which said the result is still more restricted than the N.H. bellmouth, which does look a little bigger.
I wonder if there is any advantage to be had by rounding out the hole in the air-box door, so that the rubber will expand full size instead of being squished into the football shaped hole?
thoughts, comments, poisonous barbs??
Geoff
I just wanted to ride
Old 07-05-2006, 09:51 AM   #2 (permalink)
Main Motorcycle: Speedmaster efi
eagle's Avatar
Other Motorcycle: '75 Bonneville T140V
I may be being dim but - why bother fitting a bellmouth at all - just junk the original one. Wouldn't you get more air through the hole? And holes are dead cheap!
Always forgive your enemies,
Nothing annoys them more
eagle is offline   Reply With Quote
Old 07-05-2006, 09:52 AM   #3 (permalink)
My sentiments exactly.
2006 Thruxton
monkeyboy is offline   Reply With Quote
Old 07-05-2006, 10:13 AM   #4 (permalink)
Main Motorcycle: 02 Bonneville
Other Motorcycle: 1972 Honda CL450 Scrambler
Don't know much about flow dynamics, but I always thought that the purpose of a bellmouth is to improve suction flow and to reduce cavitation (at least that's what I've been taught where aircraft jet engines are concerned). How much of a difference it makes in front of the airfilter as opposed to in front of the carb intakes is probably debateable (I would guess in front of the carb intake will make more of a difference in performance).
As far as re-shaping the hole (oval compared to round)...the surface area should be the same as should be the amount of air going through it, the dimensions will be different due to the difference in shape.
Even though I have the polaris bellmouth installed, I don't know if it makes any noticeable performance difference compared to not having it at all. It does clean-up the appearance of the hole (which you can't see under the side cover anyway) but it sure makes the bike intake sound cool in my opinion above around 3500 RPM...I'm talking some serious "Hoover Action".
Shorty
Different Strokes, for different folks.
2002 Red & Silver Bonneville
http://i22.photobucket.com/albums/b3...Bonneville.jpg
http://i22.photobucket.com/albums/b3...4/e0d93963.jpg
Shorty is offline   Reply With Quote
Old 07-05-2006, 01:01 PM   #5 (permalink)
Different than no bellmouth at all?
I always thought the best way would be to put some foam around the three sides so it seals the sidecover to the airbox, and leaving the front as a scoop. Maybe even cutting the front off a little to open it up more.
2006 Thruxton
Old 07-05-2006, 01:12 PM   #6 (permalink)
I've been thinking about bell-mouthed air scoops pointing into the airflow also. Been looking around the plant to see if I can adapt some s***** parts to play with (we work on Aircraft Engines) but haven't found anything suitable. Kinda like a velocity stack, but I hear that someone sells them for HD's (Kuryakin I believe) and they say that they don't really work all that good to make a noticeable performance difference.
Shorty
I can't believe they edited s.c.r.a.p
[ This message was edited by: Shorty on 2006-07-05 12:14 ]
Old 07-05-2006, 01:35 PM   #7 (permalink)
The content filter has Tourettes.
I understand what you mean. I thought about bending up a small sheet metal one and riveting it on.
The large snorkel is only there to keep the sound down. That's gotta go.
2006 Thruxton
Old 07-05-2006, 01:52 PM   #8 (permalink)
eagle's Avatar
Yeah - a snorkel - and no flippers? What were Triumph thinking of? :razz:
Phase one is done!!!! Kramocker Twins Technical Talk 3 10-07-2007 10:45 PM
trial and error - phase 1 Alpha Hinckley Classic Triples 8 06-10-2007 12:45 PM
Polaris "bell mouth" kliff Maintenance & Workshop Talk 2 08-09-2006 05:31 PM
Bell Mouth Not Enough.. 6449 Club Cafe' 20 06-06-2006 01:32 PM
Phase 3 belt primary drive? jimmyjam Classic, Vintage & Veteran 4 10-28-2005 02:08 PM
