Will a different front sprocket affect your tachometer? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-29-2013, 06:29 PM Thread Starter
Main Motorcycle: '11 T100 EFI
Other Motorcycle: 7 ply maple skateboard
Extra Motorcycle: '76 Honda cb200t
I guess a better question is how the tach is driven on efi Bonnies with the digital odometer? I recently put a 17 tooth front sprocket on which has significantly thrown the speedometer off. Wondering if it's thrown off the tach also. It seems to be close but I'm not sure. By the way has anyone corrected their Bonnie speedo for a 17 tooth front sprocket with tuneecu?
welfarebanks is online now
post #2 of 14 (permalink) Old 11-29-2013, 07:37 PM
Main Motorcycle: 2006 Triumph Scrambler
Tachometer will NOT be affected by your gearing.
06 HD 1200C, 06 Tri Scram, 01 Duc M900, 01 Hon XR650L, 94 HD Heritage, 89 Hon Hawk GT, 78 Hon CB750K / sidecar, 77 Guzzi LeMans, 76 Hon CB750K, 65 Hon 305, 73 Nort 850, 71 Tri TR6C, 70 Hon CT90, 70 Tri TR6, 73 Hon Z50, 70 Suz T250, 71 Yam RT1 360
lrutt is offline
post #3 of 14 (permalink) Old 11-29-2013, 08:19 PM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2000 H-D Superglide
How is your speedo driven ? Must be driven at the gear box or a sensor there. That method doesn't work well with gear changes. Doesn't effect the tach , though.
duc96cr is offline
post #4 of 14 (permalink) Old 11-29-2013, 08:31 PM Thread Starter
Cool. So does anyone know how the tach is driven?
post #5 of 14 (permalink) Old 11-29-2013, 09:32 PM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
rpms come off the spark events...
beemerrich is offline
post #6 of 14 (permalink) Old 11-29-2013, 11:38 PM
Main Motorcycle: 2005 FZ1
Other Motorcycle: FZ 09
Extra Motorcycle: 2013 Standard Aurum Gold
Wink
It's electiconical.
vitesse is offline
post #7 of 14 (permalink) Old 11-30-2013, 08:11 AM
Main Motorcycle: '07 Triumph T100
On my carb'd bike, the speedometer sensor is driven off of the rotations at the front tire. A change in the size of the tire will affect your speed. I don't think efi bikes do it another way... As for RPM, the sensor is driven by spark events. Those occur before the gears, so gearing doesn't affect tachometers.
RPM stands for rotations per minute of the pistons in the engine, not the wheel.
You'll see higher RPMs at 60mph with a 17t than a 19t. Hold the speed steady and your RPM will be different. Just like a bicycle, when you switch front a large front sprocket to a smaller one, the pedaling is easier... But you have to pedal faster to maintain the same speed.
IwannaGoFast is offline
post #8 of 14 (permalink) Old 11-30-2013, 09:41 AM
Main Motorcycle: The one I'm on, mostly.
A sensor called the crank position indicator keeps track of the alternator shell. Each time it comes around, the engine has made another revolution. The crank position indicator doesn't count sparks. On an EFI bike the information the crank position indicator provides helps the ECU decide when to make the spark and when to open the fuel injectors. The crank position indicator doesn't know you changed your sprocket so it is unaffected by the change.
Because Triumph's Bonneville chain kit comes with a 17 tooth front sprocket, I've been running with a 17 tooth sprocket since my last chain change -- 13,000 miles ago. I have a 2010 T100 and used TuenECU to re-calibrate my speedo. I think I set it to -9%.
Charles Lathe is offline
post #9 of 14 (permalink) Old 11-30-2013, 10:20 AM Thread Starter
Thanks Charles. Exactly what I was looking for. Like I said, the tach seemed right but there's no way I was doing 70mph in 2nd gear
post #10 of 14 (permalink) Old 11-30-2013, 03:43 PM
Main Motorcycle: 2010 Thruxton
Colin Doust's Avatar
The sharing of information is a wonderful thing and internet forums can be a great place to do it. Regardless of the type of information being shared, it needs to be correct.
RPM represents Revolutions Per Minute and refers to the revolutions of the crankshaft. Pistons don't rotate.
Colin Doust is offline
Change front sprocket or rear sprocket? scoutpilot Speed Triple Forum 41 10-24-2013 08:41 PM
O2 Sensor Removal's Affect On Adaption? bluesman77 Twins Technical Talk 70 10-10-2013 08:46 AM
Front sprocket nut bottoming out on end of output shaft.Cant fullytighten sprocket.. evanoverdrive Twins Technical Talk 11 03-16-2012 08:28 PM
Replacing Front sprocket, back sprocket and chain or tr6rv 75jazz Classic, Vintage & Veteran 10 08-19-2011 08:20 PM
