Motorcycle.com
Old 06-23-2006   #11 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
Dawg,
They are just near the carby heaters (those wires that hang off the bottom) Unplug the wires,the one on the right carb is in front of them and behind them on the left carb.
Depending on the year model,bugger I see you have a 05 you will need a d-tool and may have to drill out the anti tamper plug,early models just need a thin flat blade screwdriver.You can insert it up the tube and turn the screw in to make it leaner and out for richer.Make sure you do them both the same.
If you dont have the hic-up when the bike is cold you can bet this is the problem.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 06-28-2006   #12 (permalink)
UPDATE:
I up'ed the idle to where I liked it (prior to adj. setting).
No hiccups as of yet on short or medium rides (hard and soft riding).
Thank you all.
dawgfan is offline   Reply With Quote
Old 06-28-2006   #13 (permalink)
If you still get the "hiccups" after raising your idle RPM then turn your pilot screws out 1/8 to 1/4 turn. I run my idle at about 1100 RPM.
Bill
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics)
BillT100 is offline   Reply With Quote
big hesitation / hiccup, help! coelacanth Twins Technical Talk 13 02-10-2008 08:49 PM
Hiccup? altlcrzy Twins Technical Talk 13 11-16-2007 10:37 AM
Tach' hookup & eng' hiccup FattRat Twins Technical Talk 10 11-17-2006 11:40 AM
Trophy Hiccup 2500 rpm finally fixed Trophy 1 04-10-2005 09:56 AM
1200 Hiccup IT'S FIXED Trophy 4 07-19-2004 12:01 PM
