Extended cables for risers? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 07-23-2013, 02:38 AM Thread Starter
Main Motorcycle: 2011 Bonneville SE
This must be a common issue, but new to me. I want to put some 3-inch risers on my Bonneville SE handlebars so I can sit a little more upright. Does anyone know of an extended control and electrical cable kit to accommodate the higher bars. I have scoured the web and found nada. Also, is handling different with risers such as these as opposed to higher bars? I welcome any and all thoughts on the subject.
Prairie Wrench is offline
post #2 of 4 (permalink) Old 07-23-2013, 02:10 PM
wol
Main Motorcycle: 1979 T140D
Other Motorcycle: T140 Rat Street Tracker
Extra Motorcycle: T140 bitza rat
Norman Hyde do a kit of Throttle cables -- Clutch cable - front brake hose - this is to suit their western bars - the cables and hose are 3 inches longer than standard - this may be enough for your needs - i fitted them to my 2003 Bonnie - didnt need to mod the wiring as there is enough slack - the longer cables are a Triumph part from another model - I have the part numbers if you want them
wol is offline
post #3 of 4 (permalink) Old 07-23-2013, 03:15 PM
Main Motorcycle: 2015 Tiger 800 XRX
jgillis's Avatar
Other Motorcycle: 1978 BMW R80/7
Extra Motorcycle: Previous bike: 2009 T100
GenMar
Check out GenMar bar risers - no cable changes necessary and they really provide an upright riding position.
2015 Tiger 800 XRX
jgillis is offline
post #4 of 4 (permalink) Old 07-23-2013, 04:48 PM
wol
It is possible to reroute the throttle cables round the other side of the headstock to give "more length" if needed
wol is offline
Extended Cables for 04 America Kremen Twins Technical Talk 4 10-25-2007 07:11 AM
extended cables? 666Bonneville Classic, Vintage & Veteran 0 06-12-2007 12:53 AM
Oil Leak & Extended Brake/Clutch Cables graciejohn2 Speed Triple Forum 3 04-03-2007 03:53 AM
