Tail light doesn't work, brake light does - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 07-07-2013, 11:07 PM Thread Starter
Main Motorcycle: 2010 Bonnevill T100
StevenAB's Avatar
Hello all,
I've spent the better part of the day trying to install my new Maund Lucas tail light. The LP marker lights are working properly (finally). The brake light is working, but the tail light will not come on. Here is what I have:
  • Maund Lucas tail light
  • Lockhart Philips Marker lights (extra wire for running lights, I'm not connecting it and it's been sealed off)
  • NB rear tail/signal light harness
The tail light has a black and red wire. Red wire of the tail light goes to the red wire of the harness and the black wire to the blue wire of the NB harness. I attached the ground of the harness to the battery while testing. I keep blowing the 5 amp fuses for the tail light and instrument lights. For ****s and giggles I replaced both 5 amp fuses with 10 and the instrument cluster fuse still blew. Even if that had worked I couldn't leave them in there. I'm thinking a bad ground,but I'll be damned if I can figure out where. Shouldn't wiring it to the battery be the best ground you can have, or is that a no, no for lights?
I'm at a loss. Can anyone help?
______________________________________________
Steven, Un piloto de motocicletas
2010 Bonneville, TORs, Progressive 440s in back, Ricor Intiminators in front, modified airbox, TTP Breather and Tune #2, AI & O2 Sensors removed.
StevenAB is online now
post #2 of 11 (permalink) Old 07-07-2013, 11:12 PM
Main Motorcycle: 2006 Bonneville T100
fordtech48's Avatar
A bad ground won't cause a fuse to blow. A bad ground or high resistance in the ground is an open. You have the hot wire going directly to ground somewhere most likely before it reaches the bulb. Shorts to ground blow fuses.
fordtech48 is offline
post #3 of 11 (permalink) Old 07-07-2013, 11:17 PM
fordtech48's Avatar
Trace the wires carefully looking for a pinched wire somewhere. Most shorts are caused by pinching a wire and causing the insulation to break and allows the wire to touch ground. Also piercing wires runs a close second to pinching them. Ever seen a car with a dim headlight on one side? That's what a bad ground will do.
post #4 of 11 (permalink) Old 07-08-2013, 11:42 AM
Main Motorcycle: Triumph Cafe
Renocafe's Avatar
bad bulb.. Process of elimination
Sent from Motorcycle.com Free App
Renocafe is offline
post #5 of 11 (permalink) Old 07-08-2013, 12:24 PM Thread Starter
StevenAB's Avatar
I checked again last night and couldn't find a pinched or exposed wire. As well this started happening while all the wires were stretched out & I was figuring out the connections.
Not a bad bulb as I've tried two and a bad bulb shouldn't keep blowing the fuses.
This has really got me bummed out as I want to use this new tail light assembly but I'm considering replacing the stock.
post #6 of 11 (permalink) Old 07-08-2013, 01:50 PM
fordtech48's Avatar
Is it possible that something is wired wrong? That would be the only other thing I could think of. Something is allowing current to flow directly to ground BEFORE the load- which is the bulb. A short to ground after the load would just be fine as the circuit must return to ground at some point. Hope you find the issue. Shorts can be tough to locate sometimes but are relatively straightforward as far as the technical aspect goes.
post #7 of 11 (permalink) Old 07-08-2013, 02:57 PM Thread Starter
StevenAB's Avatar
Well there are only 3 wires. One is a ground with a connector on it to be grounded to the frame or some such thing (I chose the battery for testing) and two other wires going into the tail light. Get those two wrong and it just doesn't work.
Very confused and disappointed with this whole thing.
Thanks for your feedback Fordtech.
post #8 of 11 (permalink) Old 07-08-2013, 06:32 PM
Ripper's Avatar
Grounding direct to the battery is as good as any other method and makes no difference.
I take it that you had the lens off the Lucas light and the bulb out during fitting? If so, check out the little contact board at the bottom of the bulb holder. It is possible for the spring to push this out, and in replacing it, it becomes rotated. There should be a small tab on it that engages in a groove in the side of the bulb holder, which gives it correct orientation, but the tab is such a loose fit in the groove. Also make doubly sure that the spring is clear of the contacts, since this could ground one of the bulb filaments, blowing the fuse. Hope this helps, there have been a couple of these cases on here just recently.
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #9 of 11 (permalink) Old 07-08-2013, 08:41 PM Thread Starter
StevenAB's Avatar
This was a great idea and I ran right outside to try it. Unfortunately it was not the answer . There were two tabs on the contact board that were really indistinguishable, so I tried it both ways and both made the tail light fuse blow.
I'm headed out now to re-replace the harness and the light unit.
post #10 of 11 (permalink) Old 07-09-2013, 09:49 PM Thread Starter
StevenAB's Avatar
Ended up putting the original harness and OEM stop light back in place. I hate to do it, but I just may take the bike and light in to my mechanic to have it done. Let him have the headache of trying to find an electrical fault!
Thanks everyone for offering your advice
Steven
New Tail Light, Brake Light Not Working slip101 Twins Technical Talk 9 06-11-2013 07:14 AM
Front brake light doesn't work eismann Daytona Deliberations 3 05-11-2011 06:20 PM
Running Tail Light not working, but Brake light does gittles17 Club Cafe' 8 04-27-2009 09:51 PM
LED tail light/brake light redden68 Classic, Vintage & Veteran 3 02-12-2009 07:56 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
