Non-resistor plugs in a Carbie Bonnie? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-14-2013, 02:58 PM   #1 (permalink)
Will running non-resistor plugs in a carbie Bonnie (with stock plug caps) cause any grief? Some bikes are cranky that way : )
Not asking permission, just experience.
thanks,
-Armen
Armen is offline   Reply With Quote
Old 01-14-2013, 03:48 PM   #2 (permalink)
Legend
Forchetto's Avatar
Resistor spark plugs reduce electromagnetic interference with on-board electronics. The only electronics in a carbed Bonnie is the CDI unit. Older CDI units on other bikes are pretty robust devices containing just thyristors and other electrically robust components, but your CDI is described as "digital", meaning it contains some more delicate electronics like memory chips, etc.
I've been running non-resistor plugs on my XV1100 for years, even though that has a similar digital ignition system as well and resistor plugs were standard on it, with no ill effect so far.
I wouldn't do it on the EFI models though, just in case.
This is what NGK have to say about it:
http://ngkntk.co.uk/index.php/techni...esistor-plugs/
Old 01-14-2013, 07:25 PM   #3 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
i run non-resistor plugs in everything if i can find them, gives more juice to fire, never any issues
rodhotter is offline   Reply With Quote
Resistor Plugs? zap-uh Classic, Vintage & Veteran 3 07-13-2011 09:13 PM
Thruxton idle and carbie question...help! Healey_100 Twins Talk 5 11-21-2006 11:25 AM
Help with carbie information. iguana Twins Technical Talk 4 10-23-2006 10:05 PM
resistor plugs? DaleE Hinckley Classic Triples 3 10-29-2005 02:54 PM
