12-25-2012, 02:01 AM
Grand Prix 500 Main Motorcycle: 2012 Scrambler
Copper exhaust crush washers - which way do the tabs go?
These copper crush washers are for an Arrow 2-to-1 exhaust on a 2012 Scrambler. See those little tabs on the sides? They are flush on one side. I assume they go up against the engine but they will fit either way. Does anybody know for sure which way they go?
Also, what's the best seal to use on these?
Permatex Ultra Copper (which stays flexible):
http://www.acehardware.com/product/i...60&cagpspn=pla
Or, maybe Wurth Exhaust Assembly Paste (which hardens stronger):
http://www.pelicanparts.com/cgi-bin/...%20gram%20tube
Thanks!
Current: 2012 Scrambler, Bitubo forks, YSS shocks, Arrow 2-to-1, 33mm DB killer, TTP tune #4, Breathe, DNA filter; O2, AI, Airbox baffle, EVAP removed, Up-N-Over, Pivot Pegs, Ventura rack.
Past: '83 Honda XR500; '84 Honda XL600; '86 Yamaha XT350
12-25-2012, 11:07 AM
SuperSport Main Motorcycle: My Thunderbird Sport
Posts: 989 Other Motorcycle: Rocket III Extra Motorcycle: 2007 Triumph Scrambler
Just a guess
I would imagine the tab side would go toward the motor, probably just a feature to hold the gasket in place while mounting the exhaust. I have always used the after market cheapo kind, never seen a tab on any I have used. I have never used any sealant either, just bolt them down good and tight and no leaks so far......
12-25-2012, 11:30 AM
SuperBike Main Motorcycle: '07 Black
+1, the tabs are there to hold the gaskets in place until you attach the headers. They work best if they are to the head side.
"Cognito Ergo Wrenchum"
12-25-2012, 11:56 AM
Grand Prix 250 Main Motorcycle: Scrambler
Posts: 75 Other Motorcycle: 08 Buell Ulysses
What Easy said. I put a little sealent on the head side to help hold them in place.
12-25-2012, 05:27 PM
Formula Extreme Main Motorcycle: 2010 Bonneville SE
You don't use any sealant on the copper washers, since that is the job that they do themselves. But if you mean sealant for the rest of the sytem I would go for the semi-flexible one.
Arrow 2-2, De-Snorkel, De-Baffle, DNA filter, TTP Tune#3, Ohlins S36E, Scottoiler, LED Lighting, Hazards, Oberon Footpegs, Digger Seat, D9 bracketry.
12-25-2012, 09:59 PM
SuperBike Main Motorcycle: '08 claret bonnie
Posts: 1,503 Other Motorcycle: '69 Kawasaki Samuri
Tabs and the like
I never bothered too much @ the tabs. Doesnt mention in the manual might be a manu feature.
The manual says to put a smear of silicon on the washer between it and head. This may just be for positioning and holding in situ. If it was necessary for actual sealing then they would say to put it on both sides of the crush washer!
As the other postee said sealant shouldnt be necessary, if mating surfaces are clean. Mine dont leak and i didnt use sealant.
12-25-2012, 11:23 PM
A little high-temp RTV won't hurt anything.
12-26-2012, 01:30 AM
Thanks for the info! I put it back together using sealant on all joints and a small amount on the copper gasket. Unfortunately, I am still getting some popping on decel.
12-26-2012, 03:09 AM
SuperStock Main Motorcycle: 2009 Triumph Speedmaster
Posts: 291 Other Motorcycle: Yamaha Seca Turbo
Let them go through a few heat cycles, probably 3 or 4 should do it. Then use a torque wrench to keep an even load on the gasket.
12-26-2012, 04:46 AM
Site Supporter Legend Main Motorcycle: 2009 Bonneville SE
Posts: 10,441 Other Motorcycle: Yamaha XV1100 Extra Motorcycle: Qingqi QM200GY-BA
Because of the presence of the Air Injection device this popping is always present but a freer after-market exhaust makes it worse. AI removal usually stops it.
With carbs, tweaking the idle mixture screws a little to richen the lower end removes most of it. With injection, a proper re-map does it, however the Factory exhaust maps won't be set for a richer low end mixture for legal emission reasons, so using those you're stuck with it.
