12-18-2012, 05:10 PM
#11 (permalink)
SuperSport Main Motorcycle: My Thunderbird Sport
Posts: 983 Other Motorcycle: Rocket III Extra Motorcycle: 2007 Triumph Scrambler
I can tell you from experience, it can also get your arse home if you happen to snap a throttle cable........
12-18-2012, 05:41 PM
#12 (permalink)
Site Supporter Team Owner Main Motorcycle: 2003 Bonnie
Posts: 4,762 Other Motorcycle: 2003 Speed Triple 955i Extra Motorcycle: Monkeybike!
Originally Posted by gbc
I can tell you from experience, it can also get your arse home if you happen to snap a clutch cable........
How??
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
12-18-2012, 07:29 PM
#13 (permalink)
SuperSport Main Motorcycle: '06 T100
Posts: 1,324 Other Motorcycle: Kawasaki KXdirtshredder Extra Motorcycle: '76 Tiger 750
Originally Posted by GDCobra
You are kidding us on right? When it's cold pull the fast idle (or choke on a carb' bike) until it warms up. Never touched my fast idle.
Your familiar sarcasm is duly noted. But being the humble guy I am, I'll put it out there: can someone give me a legitimate answer as to why my way of doing it is wrong? Other than "that's not how I do it." I'd love to learn something.
If I leave my idle adjustment alone, it won't run well until its completely warmed up. It idles around 400 rpms. But I don't like to leave the choke on longer than :30 seconds - 1 minute. It's way too rich. And driving in 40°F weather, it's not warmed up for a good 15 minutes or so of riding. I can clearly hear from the idle when it smoothes out nicely, after about 30 seconds, when the choke is no longer needed.
BTW to my knowledge EFI bikes don't have anything to compare to a choke. Your fast idle compares to our idle adjustment, but the choke is unique to the carbs.
Bron-Yr-Aur Garage
12-18-2012, 10:21 PM
#14 (permalink)
Originally Posted by Demonic
How??
My mistake, THROTTLE cable..........That's the one that controls the gas, right.......
I really should look into that rider improvement course and quit posting after a couple of cold ones...........
12-18-2012, 10:27 PM
#15 (permalink)
Grand Prix 500 Main Motorcycle: 2007 T100
Posts: 137 Other Motorcycle: 250 Puch - long gone....
yea .. choke works fine. I gradually push it in as she warms up. OOp.. that didn't sound right.
12-18-2012, 11:21 PM
#16 (permalink)
my first bike....got pulled over on freeway because "I thought you were on fire." - they called it 'Smokey'
12-19-2012, 09:21 AM
#17 (permalink)
SuperBike Main Motorcycle: Triumph Thruxton EFi
Posts: 1,678 Other Motorcycle: Yamaha R1, Honda CB1000R
No sarcasm intended (that time), I guess there's nothing wrong with what you are doing it just sounds like a bit of a faff, also you are in a different situation to me as you have a carb' bike, on my EFi the 'choke' only lifts the idle no alters the mixture, can't you just "push it (the choke) in slowly until she warms up" as Dave suggested?
12-19-2012, 09:52 AM
#18 (permalink)
 Hahaha, good one... Dunno about the way others do it, but my choke's either on or off. Finding a halfway position would take more finessing than a quick twist o' the idle adjuster knob. It just works well for me and I always assumed that's what the idle adjuster was for (the way I use it) since it's so easily accessible.
Now I've changed carbs and have to learn all over again how to even start the temperamental beast!
Bron-Yr-Aur Garage
12-19-2012, 11:27 AM
#19 (permalink)
Formula Extreme Main Motorcycle: Triumph Street Triple
Posts: 560 Other Motorcycle: 2012 Bonneville Standard Extra Motorcycle: 2008 Harley Street Glide
I just use my fast idle all the way out to start it. Then push it in half way to help warm it up.then push it all the way in after getting up to speed. EFI bike.
12-19-2012, 07:36 PM
#20 (permalink)
Formula Extreme Main Motorcycle: '01 Triumph Bonneville
Found a solution, see below****How do you guys set your idle without a tach? I just set it by ear but I'm really not sure what RPMs I'm at to be honest.
After Forchetto's brilliant recommendation, I bought this: http://www.ebay.com/itm/Briggs-Strat...item232616e96a
