Since these are 43 mm forks, you will have to swap out the entire front end and not simply slip the tubes up into the stock triple trees (bonnie forks are 41mm). Given that, you can use any year you wish since you need to adapt the triple trees/install the correct fork stem to get this to work.
Rear wheel fitment is unknown.
Regards,
--Rich
