12-13-2012, 12:33 PM
Formula Extreme Main Motorcycle: 2012 Thruxton 900 Bianca
quick rectifier relocaton question
I found lots of usefull Rectifier relocation threads. just one quick confirmation.
Will the existing wiring lenght reach the new spot? if i understand correctly it means the connector may be outside the headlight bucket to reach. That's when i use the self amalgamating tape to seal it right? but i've also heard that i can get it to reach with the connector staying in the bucket. What do you guys think? which is it? will i need to lengthen the loom?
Thanks.
12-13-2012, 12:55 PM
Formula Extreme Main Motorcycle: 2008 T100
I was able to find just enough lenght to move mine without having to pull it from the bucket. There wasn't much length left over so you'd want to turn your bars full lock left and right to determine if you need to worry about the connectors being pulled apart after it's been relocated.
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 150mains/45 pilots, no shim, -2.0 turns out @ sea level, green springs
12-13-2012, 01:38 PM
So just pull wire out of the bucket with the rectifier? Leaving the connectors in the bucket. Sounds easy enough. I'll give it a go and see what happens. Thanks.
12-13-2012, 02:07 PM
SuperStock Main Motorcycle: 2012 Thruxton
Posts: 241 Other Motorcycle: FeltVintageIronCross400
Where are you planning to relocate it?
At some point, I'd like to upgrade to a mofset unit and tuck it away outta sight...
If I understand correctly, the OE model should have decent airflow.
'12 Thruxton, de-baffled, de-snorkeled, AI removed, O2 disabled, DNA filter, TTP Breathe, TTP tune #3, Dominator Sports, Maund FEK, Cibie Headlight
12-13-2012, 03:37 PM
I'm just doing the usual location. Bella corse model relocate to next to the oil cooler
12-13-2012, 10:34 PM
There's an extension cable available.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
12-13-2012, 11:02 PM
That's convenient. Why haven't I seen that. I'm guessing its on one of the usual triumph sites?
12-13-2012, 11:08 PM
SuperSport Main Motorcycle: '06 T100
Posts: 1,310 Other Motorcycle: Kawasaki KXdirtshredder Extra Motorcycle: '76 Tiger 750
/M
You got 'em, Mike?
I've been brainstorming the same as OP. I have the Mosfet, but want to relocate it to my battery box. From what I understand the harness can be split through the tape to isolate the R/R wires, but it would be nice not to have to do that.
Regarding OP, I have my original R/R relocated, for the time being, to the stock horn location. I couldn't keep the connector in the bucket. FWIW it's a hideous eyesore to me. I can't wait to get that project finished.
Bron-Yr-Aur Garage
12-14-2012, 12:02 AM
SOTP Vintage Series Main Motorcycle: 2006 Blue Thruxton
Posts: 6,368 Other Motorcycle: 06 Thruxton - wife's bike Extra Motorcycle: CB400SF, 4 x DT175, MX80
+1 for the harness extension please. I have the R/R but have been reluctant to cut into the harness.
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
12-14-2012, 09:41 AM
I'm simply not good enough at electrical yet to cut into the loom.
