12-12-2012, 02:52 AM
Site Supporter Formula Extreme Main Motorcycle: '11 Speed Triple
Posts: 417 Other Motorcycle: '13 Mag Wheel Bonnie
Removing Rear Wheel Nut - What Size?
What tools do I need to remove the nut as seen in this picture for a 2013 mag bonniville?
I guess whatever size socket/wrench to remove the tire is what I need. Might as well get it all.
Thanks!
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
12-12-2012, 04:38 AM
Site Supporter Supersport 600 Main Motorcycle: Bonneville SE
Posts: 175 Other Motorcycle: No need
Mag bonneville with spoked wheels!
My 2010 mag bonneville uses 24mm socket one side and 19mm spanner on the other side.
12-12-2012, 04:53 AM
SuperSport Main Motorcycle: Triumph Bonneville
Sir is right.
Plasma.
12-12-2012, 11:46 AM
Thank you sir.
12-12-2012, 07:12 PM
Formula Extreme Main Motorcycle: 2012 base bonneville
Posts: 680 Extra Motorcycle: 2006 XL1200L
you can download an instruction sheet for the belt drive i installed at scootworks.com has all sizes + torques and instruction to install belt as well as a one piece chain not using a master it shows removing rear swingarm
12-12-2012, 07:23 PM
SuperSport Main Motorcycle: 2007 Bonnie T100
Posts: 1,150 Other Motorcycle: Jeep Wrangler
if you don't have metric spanners, 3/4" and 15/16" is a precise fit, matter of fact the latter fits snugger
2007 B&W T100.
AI & Snorkel gone, Dom Tourers, 40/120/1 shim 3 turns, TTP stage one, Dart screen, Pingel fuel valve, Monza gas cap, Avon Roadriders, Triumph fabric saddle bags sometimes
I like a man who grins when he fights - Winston Churchill
12-13-2012, 01:58 AM
SuperBike Main Motorcycle: '08 claret bonnie
Posts: 1,503 Other Motorcycle: '69 Kawasaki Samuri
Whitworth
1/2 " whitworth is i think the snuggest fit. No rounding to the bolt head. Oh and just use a stilson on the other end!!
12-13-2012, 02:08 AM
Ok I'll see what I have in standard. I bought the tools suggested but don't mind getting whatever is needed for proper fitment. I am building my collection.
What is a stilson?
Gonna do shop tomorrow night.
12-13-2012, 04:55 AM
What is a stilson?
Askari is just having a little joke with you,a Stilson is a plumbers tool.
Plasma.
12-13-2012, 04:57 AM
Tongue in cheek!
What is a stilson?
A stilson is often called a pipe wrench and is not to be used on your pride and joy. It is about as far removed from a well fitting spanner as you can get!
At the end of the day the most important thing is fit. So if you only have an A/F spanner and it fits well, then use it.
