Removing Rear Wheel Nut - What Size? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Old 12-13-2012, 11:37 AM   #11 (permalink)
Main Motorcycle: Bonnie T 100
Crackon's Avatar
Originally Posted by Askari View Post
A stilson is often called a pipe wrench and is not to be used on your pride and joy. It is about as far removed from a well fitting spanner as you can get!
At the end of the day the most important thing is fit. So if you only have an A/F spanner and it fits well, then use it.
WOT! Are you knocking my tool kit? 18" Stilson, 6" Stilson 2lb ball pein hammer and cold chisel. Move anything!!
Crackon is online now   Reply With Quote
Old 12-13-2012, 12:32 PM   #12 (permalink)
Main Motorcycle: Bonnie, what else?
Other Motorcycle: B25
Extra Motorcycle: T140
Add a 4lb lump hammer & an old fork stanchion (for leverage) and you can call it complete.
2003 Black Bonnie: snorkel, A/B baffle & AI removed, 650 Bonnie straight through Campbell silencers, IKON shocks, CBR600 F3 forks, FJ1200 swan-neck clipons (winter) GSX flat clipons (summer), Procon igniter, Tiger alloy rim+150/70/70 rear tyre
Dayve is online now   Reply With Quote
removing the rear wheel jnicosia Speed Triple Forum 10 02-11-2009 08:58 PM
Removing Rear Wheel Without a Paddock Stand HoustonTriple Speed Triple Forum 7 05-17-2007 08:49 AM
Removing the rear wheel blinker Speed Triple Forum 16 07-27-2006 04:16 PM
Removing Rear Wheel msparks Sprint Forum 6 08-08-2005 05:49 PM
Removing & Replacing rear wheel on Y2K-TBS Maintenance & Workshop Talk 29 07-29-2003 06:38 PM
