12-07-2012, 10:41 PM
Supersport 400 Main Motorcycle: 2012 Scrambler
Will my engine adapt if my idle speed is high?
I have a 2012 Scrambler. Is it true the ECU adaptation cycle (idling the cold engine for 15-20 minutes) will not work if the idle speed is too high? If so, what is the upper idle speed at which the adaptation procedure stops working? Thanks!
Current: 2012 Scrambler, Bitubo forks, YSS shocks, Arrow 2-to-1, 33mm DB killer, TTP tune #4, Breathe, DNA filter; O2, AI, Airbox baffle, EVAP removed, Up-N-Over, Pivot Pegs, Ventura rack.
Past: '83 Honda XR500; '84 Honda XL600; '86 Yamaha XT350
12-07-2012, 11:09 PM
Site Supporter Legend Main Motorcycle: 2009 Bonneville SE
Posts: 10,120 Other Motorcycle: Yamaha XV1100 Extra Motorcycle: Qingqi QM200GY-BA
Not heard about that, however the adaption procedure won't work if the O2 sensors have been removed as yours seems to have, judging by your signature. What will work by idling for 10-15 minutes is the TPS reset so it's still worth doing after any work or re-mapping.
12-08-2012, 12:53 AM
OK, I did not think that sounded correct. I read it here in post #9.
http://www.triumphrat.net/twins-tech...dle-speed.html
I am going to start a new thread because I have narrowed down my problem (which was popping on decel).
Here is the new thread:
http://www.triumphrat.net/twins-tech...-position.html
THANKS!
12-08-2012, 01:57 AM
SuperSport Main Motorcycle: '67 Rickmann Metisse
Posts: 998 Other Motorcycle: first bike: '64 Yamaha 80 Extra Motorcycle: Wish I kept: '69 Trident
I don't know about your Scrambler, but what you are asking is definitely true on a 2009 EFI T100. I found this out the hard way, and verified by Mickey Cohen who maintains and manages Triumph USA's press fleet. I forget the idle speed required to adapt and learn, but it's pretty low.
dk
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
12-08-2012, 03:55 AM
SuperBike Main Motorcycle: Triumph Thruxton EFi
Posts: 1,661 Other Motorcycle: Yamaha R1, Honda CB1000R
If the speed is such that the map is in a zone where the fuelling is not in closed loop mode (which is quite low on the Arrows 2:2 on my bike) then it won't adapt, there may also be a limit built into the map which disables the procedure, when I took mine to the dealers for the 'urban tune' they mentioned the idle issue.
Another way to look at it is if you are in spec' it can't be wrong.
12-08-2012, 10:27 AM
I do have the O2 removed. However, I thought it could still adapt using the air temp and pressure sensors. At any rate, my idle speed is not above 1100 so it should be okay.
12-08-2012, 02:03 PM
It will adapt as it goes on from day to day according to ambient temperatures and altitudes, what doesn't work is the adaption procedure. This was pointed out to me on the adaption thread way back in 2010. See post 11 from DEcosse on this thread:
http://www.triumphrat.net/twins-tech...procedure.html
And further discussed here:
http://www.triumphrat.net/twins-tech...-adaption.html
