Simple Mods - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.comSportbikeTrackGear
Old 12-07-2012, 09:19 PM   #1 (permalink)
Main Motorcycle: Bonneville
Simple Mods
After a few weeks of reading about various mods, I carried out a couple:
Disable AI - made a little difference to the mpg etc
Removed the snorkel - huge difference, makes it sound a bit throatier when accelerating and a bit quicker I think.
I was wondering if there were any other simple mods I may have missed that can make a difference to the performance?
Mr*Beaver is offline   Reply With Quote
Old 12-07-2012, 11:12 PM   #2 (permalink)
Remove your muffler baffles and bump the mains to 115.
Change out your headlight for a Hella unit.
Replace your tires with Pirelli sport demons.
Clean and lube your chain ever 400-500 miles.
Remove your breather hose from your airbox and run a breather filter.
luckyduck is offline   Reply With Quote
Old 12-08-2012, 07:02 AM   #3 (permalink)
Look in the stickys, there's a host of different mods, many with step by step instructions and photos by members that know what they're talking about.
Old 12-08-2012, 09:06 PM   #4 (permalink)
Main Motorcycle: '07 Black
Easy13's Avatar
17 tooth countershaft sprocket. Unless you run flat out and want top end speed, a 17t is an all-round winner. Big boost in low/midrange acceleration.
"Cognito Ergo Wrenchum"
Easy13 is online now   Reply With Quote
Old 12-10-2012, 04:46 AM   #5 (permalink)
I don't think I elaborated enough, maybe I should rename it under $50 £35 mods?
Easy13 - thats quite a good one
Old 12-10-2012, 10:42 AM   #6 (permalink)
Main Motorcycle: '06 T100
Bron-Yr-Aur's Avatar
Other Motorcycle: Kawasaki KXdirtshredder
Extra Motorcycle: '76 Tiger 750
Handle bars - change the look and comfort level
Mirrors - IMO a much-needed change to the look of the bike
Turn signals
Tail light
I'd set my my $ limits a little higher, though. Suspension could use help and dwells more in the domain of safety than just looks. You don't have to spend a lot to make it better, but more than $50.
Bron-Yr-Aur Garage
Bron-Yr-Aur is online now   Reply With Quote
Old 12-10-2012, 11:03 AM   #7 (permalink)
richm's Avatar
Get rid of the air box baffle - a couple of hours work if you take it steady, but it's free. You'll need to re-jet though (so, I guess it's not quite free, but is cheap).
richm is offline   Reply With Quote
Old 12-10-2012, 11:41 AM   #8 (permalink)
Mr Beaver. Are you looking for performance mods or otherwise ?
If it's performance the first thing you need to do is fit open exhausts. There's plenty you can do on the intake side for little or no outlay but you're not going to gain much benefit with the highly restricted stockers.
Open pipes, no AI, snorkel, air box baffle removal and bigger main jets should give you another 10 bhp at the rear wheel. That's good bang for buck.
Three simple but effective mods 02Blue1200 Trophy 16 10-29-2009 04:34 PM
Simple Bonnie Mods TowerGuy Twins Technical Talk 23 01-18-2009 02:56 PM
So simple, even a ....could do it! BonnieGreenDon Twins Technical Talk 6 01-11-2008 11:54 PM
simple is better TB-T100 Twins Technical Talk 12 10-15-2007 12:49 PM
More Simple Mods..... WardenRoss Sprint Forum 12 08-15-2007 11:09 PM
