Which Shorai Battery - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 12-11-2012, 10:43 AM   #11 (permalink)
Main Motorcycle: I can't decide!
Hypurone's Avatar
Other Motorcycle: Ducati Monster S4RS
Originally Posted by bonza View Post
I found that very interesting.
does this also apply with other batteries like lead acid, etc?
and could this be valid for EFI bikes that have trouble starting in low temps as reported in other posts?
Lead acid batteries can recover some of their state of charge by being "warmed" but not nearly as much as an LiFe battery can/will.
As for EFI bikes. The only difference would be how much of a draw during key off and for how long between charges you go. You would want to have the higher AH reserve to cope better with the key off draw for extended periods if the bike is not ridden regularly. Unless you use a tender or disconnect the - cable. Then you could get away with the smaller AH reserve unit if you really needed to save a few bucks....
Plus the weight savings is huge @ 2.31lbs vs 10!
FAQ's here:
http://www.shoraipower.com/s.nl/it.I/id.5/.f
Chuck
'10 Thruxton 944cc - In the Faster Color
"Ridin' It Like I Stole It"
Hypurone is offline   Reply With Quote
Old 12-12-2012, 11:53 AM   #12 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
thanks for the info, i am only learning about lith-- batt the weight savings is a no-brainer and as technology increases they may replace conventional batteries if the prices come down as it could with more sales
rodhotter is offline   Reply With Quote
Shorai Battery Keltriple Speed Triple Forum 110 12-20-2012 02:21 PM
Battery Box delete and install of Shorai Battery on my 07 Thruxton SouthofHeaven Club Cafe' 29 10-17-2011 08:09 PM
Shorai battery Wayne's Striple Street Triple Forum 8 10-03-2011 09:32 AM
Shorai Battery briclark1 Speed Triple Forum 0 04-11-2011 05:38 PM
