Hi any help appreciated !
Gas leaking from Pod.
Just had carbs off to make sure the idle circuit was was clean as I was running lean at idle after installing BC air box delete. With Thier 42s and 140 jets. At 2.5 turns now.
Bike will turn over after much cranking but does not stay on...
With pet cock on gas pours from left pod...
At least it was running yesterday if not ideally... Geez. What did I do wrong ? The carb assemble seemed straight forward at the time...
