Bonneville modified air intake - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Old 12-05-2012, 04:00 PM   #1 (permalink)
Main Motorcycle: Bonneville T100 EFI
Yet an other air intake.
After taking a lot of time reading the posts talking about the Bonneville airbox on this forum, I decided to remove the snorkel and the restrictor plate on my 2011 EFI Bonnie. Since then, the engine breathes much better.
But the hole remaining in the air filter holding plate could be enlarged a bit more.
So I cut the inner side and fitted a plastiline half round bell mouth to give a better look. I'm not sure that this shape will be "scientifically" efficient as a computed designed velocity stack but this round shape smoothe the airflow better than a sharp one.
I made a flexible silicon mould and cast one with black polyurethane resin. A silicon gasket is fitted on the inner side, where the original one was hiding, to keep the airbox airtight.
After a few experiments with bubbles tracking and elimination, the result is quite solid and fits perfectly.
I was thinking of fitting a wire mesh to prevent things to get in the filter. But I have been using this device like that for a few months and for now, I didn't find any grasshopper, nuts, or Harley Davidson part inside
Even in heavy rain condition, the air filter never seems to be soaked or wet.
Tell me about your experiences with your mods on air intakes.
Bonneville modified air intake-air-intake-02.jpg   Bonneville modified air intake-air-intake-01.jpg   Bonneville modified air intake-air-intake-03.jpg
Bonn3vill3 is offline   Reply With Quote
Old 12-05-2012, 04:12 PM   #2 (permalink)
I just removed the whole snorkel piece and put the Polaris rubber bell mouth in it's place. It has only been a couple of days since this mod. It feels a little snappier at throttle, mpg wise I don't have enough data. That the big payoff hopefully the mpg s will go up a little.
shelglass is offline   Reply With Quote
Old 12-05-2012, 04:40 PM   #3 (permalink)
I made the exact same thing out of car body filler.
Old 12-05-2012, 04:48 PM   #4 (permalink)
Main Motorcycle: 2011 Bonneville T100
TWinOKC's Avatar
Other Motorcycle: 2010 Royal Enfield C5
Is it necessary to remap after removing the snorkel and restrictor plate?
Is the baffle same as restrictor plate?
TWinOKC is online now   Reply With Quote
Old 12-05-2012, 05:00 PM   #5 (permalink)
Yes and yes.
Old 12-05-2012, 05:08 PM   #6 (permalink)
Wow this looks great! Similar in profile to the TTB Breathe bellmouth.
Anyhow, any chance you could make me one of these to fit onto my air filter retainer?
Thanks!
luckyduck is online now   Reply With Quote
Old 12-05-2012, 05:16 PM   #7 (permalink)
Main Motorcycle: 2010 Triumph Scrambler
Looks nice! I'd put one on my bike if I still had my airbox. =)
- Eddie
casida is offline   Reply With Quote
Old 12-05-2012, 05:53 PM   #8 (permalink)
They're easy enough to make yourself using car body filler. All you do is roughen the surface to make the filler key to it, build the filler up gradually and spend half an hour with rubbing down paper to perfect the shape. Add a lick of black paint to make it look pretty and that's it. I've had mine on for 6 months, works great.
Old 12-05-2012, 06:22 PM   #9 (permalink)
Gotcha. I'll do that.
Old 12-14-2012, 07:56 PM   #10 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
looks good, i would feel better with a K+N filter as far as water or foreign objects are concerned
rodhotter is offline   Reply With Quote
Bonneville EFI Map for Staintunes & modified or no snorkle ??? mischief Twins Technical Talk 9 11-08-2012 12:58 AM
Modified intake side cover Slinky Twins Technical Talk 43 10-21-2010 06:34 PM
Fender Modified martingilly Hinckley Classic Triples 1 10-28-2006 12:01 PM
Modified Bonnie Tomus Club Cafe' 4 04-04-2005 10:32 PM
Modified Tbird 955Tbird Maintenance & Workshop Talk 5 04-09-2004 11:02 AM
