Originally Posted by luckyduck
Still stumbles now again with hesitation at part throttle, but it's running much much better.
That's about where I'm at now as well. I have a spare igniter and P/U coil that I want to try for nits-n-giggles, but being wet/cold, not sure when I'll have an opportunity to do that. If I do, I'm still going to do one at a time so I can eliminate either one or both as possible causes.
Did you ever crack your alternator cover to check the gap on the P/U coil?
I'm just curious if either running Iridium plugs or simply indexing the plugs wouldn't take care of the occasional hiccup or stumble at dead stop idle.
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 145 mains/42 pilots, no shim, -1 turn out @ sea level, green springs
