12-03-2012, 12:14 PM
Grand Prix 125 Main Motorcycle: Triumph Bonneville T100
Tool Kit?
I am not a mechanic and I am not very fix it like, but, that being said, I need to start to put together a set of tools to do basic maintenance/etc on my T100.
Is there a good KIT out there that would be a good fit for my Bonneville (2012)? Like, something in the $100-$200 price range that comes with just about any tool I would need to work on this particular bike?
Also, being that it's a British bike, are all the nuts and bolts on it Metric, or is there some standard stuff (American) on it as well?
Thanks for any info and advice...
D.
12-03-2012, 12:38 PM
Site Supporter Team Owner Main Motorcycle: 2003 Bonnie
Posts: 4,769 Other Motorcycle: 2003 Speed Triple 955i Extra Motorcycle: Monkeybike!
Get yourself a set of quality spanners, Allan keys, and a good set of sockets. Everything else, buy it when you need it. I've got boxes full of tools that I will never, ever use...
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
12-03-2012, 01:28 PM
Formula Extreme Main Motorcycle: Suzuki GSF 1250S Bandit
Everything's metric. It will probably work out cheaper to build your own tool kit instead of buying a ready made one.
12-03-2012, 01:53 PM
Powerbike Main Motorcycle: Thruxton 04
Posts: 392 Other Motorcycle: Ariel VHA Special Extra Motorcycle: Honda Pan European ST1300
As above and get a manual
12-03-2012, 02:09 PM
Formula Extreme Main Motorcycle: 2008 T100
Originally Posted by tonupdave
...and get a manual
This being the most valuable tool.
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 145 mains/42 pilots, no shim, -1 turn out @ sea level, green springs
12-03-2012, 02:22 PM
12-03-2012, 02:52 PM
Haynes manuals are a "must have" tool for anyone wanting to service, maintain and repair their bike or car.
12-03-2012, 03:01 PM
Groovy...
Thanks for the tips ya'll.
d
12-03-2012, 03:18 PM
Tools you should have for starters.
Set of Allen keys
Combination wrench set from 6 - 19 mm
Socket set 6 - 19mm plus additional sockets to fit the countershaft nut and one for the rear wheel spindle nut...I think they're 24 and 34 mm, not sure.
Long nosed pliers and ordinary ones.
Good quality screwdriver and bit set.
Torque wrench.
