Originally Posted by Aussie_T100
The following is a tool list & their applications that I compiled for my 2008 carbed T100 with some mods.
Hinkley Bonneville Tool List and their uses:-
3mm Allen key:- Float bowls*, Carby tops*, front guard stays.
4mm Allen key:- Carby bellmouths*, flyscreen*.
5mm Allen key:- Seat, Grab rail*, Number plate*, Front guard, Switch gear, gear lever.
6mm Allen key:- Rear M/cyl, H/bar clamp, front axle clamp, chain guard, muffler clamps, cam cover.
8mm Allen key:- Foot peg brackets, triple tree clamps, frame down tubes, center stand*, exhaust header mounts, brake pedal.
Medium Phillips screwdriver:- Battery terminals, M/cyl reservoir lids, Air filter clamps, Carby clamps, headlight.
Medium flat screwdriver:- Side covers.
Small flat screwdriver:- Carby jets.
8mm socket:- Fuel tank, oil cooler, engine covers, rectifier, air filter, starter motor, Chain adjusters.
10mm socket:- front guard brackets, igniter, tailight, cam oil feed pipe, starter terminal, solenoid terminals, clutch bolts.
12mm socket:- Top engine brace, rear shocks, headlight, front caliper, exhaust headers, breast plate, horn.
13mm socket:- Sump plug.
14mm socket:- H/bar risers, rear caliper, Centre stand*, rear sprocket.
16mm socket:- Engine mounts.
17mm socket:- Engine mounts, sidestand, swingarm.
18mm deep socket:- Sparkplugs.
19mm socket:- Oil cooler lines.
1/4" socket:- fuel line clamp*.
9/16" socket:- Brake line banjo bolts.
8mm open end / ring spanner:- Inlet manifold.
10mm open end / ring spanner:- Number plate*, Throttle cables.
12mm open end / ring spanner:- Fork brace, rear footpegs, clutch cable, rear shocks.
13mm open end / ring spanner:- Engine brace, muffler brackets*.
17mm open end / ring spanner:- Sidestand, engine mounts.
19mm open end / ring spanner:- Front axle, rear axle.
22mm open end / ring spanner:- Oil pressure switch.
24mm open end / ring spanner:- Front axle, rear axle, oil cooler lines, swingarm.
T30 Torx key:- Chain guard, rear mudguard, cam caps, ignition pickup, sidestand switch.
100mm adjustable wrench:- Substitute for 9/16" socket etc.
200mm adjustable wrench:- Substitute for 16mm socket & 22mm open end etc.
Ratchet handle(s), long & short extensions as required for sockets (1/4" & 3/8").
Small pliers for electrical work etc.
Items marked with an * are unique to my bike because of a fitted accessory or aftermarket item.
