I also cannot condone scotch-locks.. especially for use in locations exposed to the elements. I couldn't count the number of times I've had vehicles come to the shop with random drivability issues which I then traced back to a scotch-lock on some funky electrical accessory installation.
One thing I would add, if you are going to use any device such as the posi-tap.. make sure you seal the tap with some silicone or something of that sort. Corrosion in your wiring harness is not fun.
bought a wrecked 2010 T100 in North GA.. so wrecked it was sold as parts only.. I'm rebuilding it. :) Build thread here
End of line.
